It is a good video and does a great job of explaining what a good weight distribution system actually does...which is distribute the weight of a trailer load evenly between all the axles. But it doesn't go that extra step and showing if using the air bags to help with the ride comfort. For example, with my setup (F-250 with a 5th wheel), I use the air bags to level up, but I also use them to help smooth the ride on really rough roads, like the concrete highway system in the Houston area (and other places). I can increase the PSI in the airbags, and it helps greatly with the bounce and jounce the roads cause. Then when I get on smoother roads again, I can let the air out to get just the leveled truck/trailer. So in this case, with a TT, would the air bags help there? Just curious more than anything, as I don't remember having too much of an issue when I pulled a TT.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
