Old 12-03-2012, 07:51 AM   #1
Adding tv to 8314BSS bedroom
We have a 2010, 8314BSS and would like to add a tv wall mount in the bedroom. Has anyone done this and if so where did you put it. Also, anyone have suggestions on a way to get satellite signal in the bedroom? We have it in the living room but not the bedroom. I appreciate any help, this would make a great winter project for DH.
maconandk is offline   Reply With Quote
Old 12-03-2012, 09:55 AM   #2
Dave_Monica's Avatar
You should have a antenna connection and 120V outlet where the optional TV is intended to be mounted. I looked up that floorplan...are they on the side of the wardrobe on the door-side wall?
I can't help you with the routing of the satellite wire. I would think that it would be near impossible to run it to the existing antenna connection.
Dave
Old 12-03-2012, 03:47 PM   #3
Yes, the antenna connection is on the wardrobe on the door-side wall. We will put tv there. Thanks for your help.
Old 12-03-2012, 04:15 PM   #4
Was there not any sticker to indicate where the TV is to be mounted? The wall has to have a backing board to mount the bracket to if it's on an interior or exterior wall.
Dave
Old 12-04-2012, 05:55 AM   #5
No sticker or any indication where to mount tv.
Old 12-04-2012, 01:01 PM   #6
Unfortunately, no 8314BSS owner with a bedroom TV option has stepped forward. You could try to email Douglas Fought at Forest River (dfought@forestriverinc.com). He's the Rockwood warranty contact and should be able to forward your question to the right person.
Dave
bed
