Old 07-16-2016, 06:06 PM   #1
Adjust Dometic frig to be colder
Have 2017 rockwood 2906ws, have read that there is adjustment tab on fins in back of frig. Mine has none. It is in slide out . I have the temp on front set to max and it barley stays in safe zone on the thermometer inside. Are there any other adjustment on this brand. Unit is level.
Jim and Silene
2017 Rockwood 2906WS
2014 Dodge Ram 1500 Hemi 5.7
Firestone Airlift 1000, Equalizer Hitch
Augustpilot is offline   Reply With Quote
Old 07-18-2016, 06:52 AM   #2
Surprised no one had had cooling problems
Has no one had Dometic cooling problems?
Jim and Silene
Old 07-18-2016, 07:07 AM   #3
No other adjustments.
Many of us with refrigerators in a slide have had to add fans (inside & outside) over and above what the factory may or may not have installed to get better temps. Makes a big difference.
Search the threads. There is a lot of good information about how to help your cooling efficiency.
I've added fans and am able to see temps below 0 in the freezer and 30-32 in the fridge.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 07-18-2016, 10:19 AM   #4
Most Dometics have the slider; it's inside the fridge. But some have a 3 position switch on the outside front of the fridge.
Fridges in slides don't have a roof vent, they have a upper side vent. So they have a harder time working as they don't get the same "chimney" effect for cooling that the non-slide ones do. That's why many of them have a fan installed, but from my reading of posts here, it doesn't sound like it's much of a fan. Lots of folks have added computer fans.
If you want better answers, suggest you post your model number.
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
Old 07-18-2016, 12:21 PM   #5
I would check out these types of fans for inside the unit. It may help, and this one seems pretty well built and fairly reasonable.
Dometic Refrigerator Fan to Increase Cooling Inside Deluxe Custom Built | eBay
foretm is offline   Reply With Quote
Old 07-18-2016, 01:13 PM   #6
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
My Norcold is in a slide and I added another fan to the condenser cooling fan outside and it gives me 0 to 5 in the freezer and occasional ice particles in my water in the fridge,,,,and that's with this 100 degree Texas heat.
Grampa Jim is offline   Reply With Quote
Old 07-18-2016, 03:46 PM   #7
MH Noob
I have a fridge in a slide on my 3120ds - I took alot of care in correcting the FR install on the Fridge as directed from the manufacturer. The first stage is to ensure correct baffling behind the fridge. Second is to inspect for any cuts or punctures in the rear of the fridge during install. Even the smallest will affect cooling. Lastly are the fans - I put two fans in the rear to add airflow - they are on a thermo switch that turns on at 85 degrees - the last bit is the interior fan that assists with moving the air around the food inside. All of these things can be found at rvcoolingunit.com great folks over there.
Slimjc is offline   Reply With Quote
Old 07-19-2016, 07:07 AM   #8
jtatum65's Avatar
X2
Jim & Evelyn Tatum
2013 Rockwood 8289WS FW
2016 Dodge Ram 2500 Big Horn 6.4L Hemi 4x4
Nights Camped 2016= 33
# of Campgrounds= 11
Nights Camped 2015= 31 @ 7 CG
jtatum65 is offline   Reply With Quote
dometic
