Old 10-01-2015, 11:23 PM   #1
Advice Please... drinking from hot tap?
Hi Ive been filling my baby's bottle from the hot tap (as its the perfect temp). However I dont know if the water heater etc is copper lined.
Does anyone know if it is safe?
2015 Rockwood 3008w
sgh77 is offline   Reply With Quote
Old 10-01-2015, 11:45 PM   #2
Copper is expensive, most are probably ceramic lined. If your comfortable with the water system it should be good. Mostly I would be concerned with the safety of the supply side, condition of the tank or hose to camper. Bottle water sitting in hot water will eliminate questions. Give the baby a tickle for me.
Timtation is offline   Reply With Quote
Old 10-02-2015, 02:14 AM   #3
wmtire's Avatar
X2 with Timtation. Most likely you have a Suburban brand water heater, which is a steel tank with a porcelain lining.
The following is taken from the manufacturer website:
Airxcel | Suburban Manufacturing Products
Longer Life
Heated water attacks all metals, but not porcelain. That's why Suburban uses a porcelain-lined, steel water heater tank with an anode rod to "absorb" the electrolytical action - just like your water heater at home. In fact, when a Suburban porcelain-lined tank is properly maintained, tank life may double or triple its three-year limited warranty, saving owners the cost of premature replacement. In addition, every Suburban tank is pressure tested twice during the manufacturing process to ensure its integrity.
If you have an Atwood brand water heater, then it's an aluminum tank:
http://www.askforatwood.com/images/W...tage-Sheet.pdf
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 10-02-2015, 02:53 AM   #4
Yes it is Suburban, cheers for that
Old 10-02-2015, 04:56 AM   #5
Oaklevel's Avatar
Ok I'm slow this AM , I know that the water heater is not copper lined but if it were why would that be an issue?????
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Oaklevel is online now   Reply With Quote
Old 10-02-2015, 05:04 AM   #6
davel1971's Avatar
I'm with you. Houses had copper pipes for years, and we lived
David & Lynn
Old 10-02-2015, 05:20 AM   #7
oldgold's Avatar
2015 Rockwood 3008w
We used nursery water from a gallon jug. Left the jug on the counter and gave him room temp bottles. He is 1.5 now. It helped tremendously because we never needed to heat or cool his bottles. Wish us luck, we got number 2 on the way.
How old is your little one?
2015 XLR Nitro 30FQSL
2015 F250 King Ranch
oldgold is offline   Reply With Quote
Old 10-02-2015, 05:26 AM   #8
Oaklevel's Avatar
It is not the copper pipes in old houses that was the issue it was the lead solder used at the joints that was the potential issue. But lead solder is no longer used. Copper piping is still used in houses but not as much as in years gone past. Mainly due to costs. Even a copper penny is no longer copper its clad. But I am not convinced that the old solders were a huge issue but that is another argument.
Our first camper had copper piping.
But I am still trying to figure out today why a copper liner in a water heater would be a bad thing.
1966 Mustang GT
1986 Mustang SVO
Old 10-02-2015, 05:45 AM   #9
nomad297's Avatar
I would like to have a copper lined water heater if there were such a thing.
And, up until about two years ago, most of the valves and faucets we plumbers used contained lead. Everything we buy at the supply house that will be connected to the potable water supply system must be lead-free now. We still use many other products containing lead, asbestos and other materials known to be bad for humans (and rats).
Bruce
Old 10-02-2015, 07:19 AM   #10
Oaklevel's Avatar
Bruce
You are exactly correct....... many people think that when the go to Lowes,
Home Depot, etc that none of the products they buy are hazardous or contain asbestos but that would not be correct. Millions of pounds of asbestos still go into building construction annually. The urban myth that anything built after 1985 does not contain asbestos, but that is far from correct. Watch for labels that say contains natural fibers because that probably has some asbestos.
1966 Mustang GT
1986 Mustang SVO
