09-23-2016, 09:15 AM
Agm battery
Hello can agm batteries be used with the rockwood mini lites? Will the inverter work? Charging ?
Thx
09-23-2016, 10:33 AM
Why wouldn't an AGM battery work?
Perhaps you could Google that information yourself to find how it directly affects TT usage.
Choosing the Best RV Battery: Which is Right for You?
2011 Nissan Xterra V6
2016 Rockwood MiniLite 2306
Nights Camped 2016 [24]
Nights Camped 2017 [63]
Nights Camped 2018 [27]
09-23-2016, 10:35 AM
I have , not finding much. Thought I read some where that the inverters would not charge them correctly.
Thx for reply
09-25-2016, 06:23 PM
I have 2 AGM's on our 2109S, one up front and one on the rear bumper.
2015 Rockwood MiniLite 2109S
2018 Ford F150, 3.5L ecoboost
Blue Ox SwayPro hitch
09-25-2016, 06:32 PM
My lite has a G27 AGM, heavy beast but it does what I need it to.
09-25-2016, 09:59 PM
AGM charging routine is generally very close to the wet cell routine and as long as you have a modern 3 or 4 stage charger, they should present NO problem. They DO like to be treated well though for best life so:
1. Always charge them fully after use. If you don't charge them to 100% their capacity will deteriorate over time.
2. Don't leave them unattended and plugged in at float charge levels for weeks at a time. Charge them fully...then disconnect at the negative terminal if you won't be visiting for a while. The SELF discharge rate is about 1/10th of the wet cell rate and they can sit for a LONG (6 months+) time unattended and hold their charge.
________
Cam
2015 Georgetown 280DS
09-25-2016, 10:28 PM
Thx
Rockwoods don't have INverters, unless a previous owner installed one.
They do have CONverters, which recharge the battery when plugged into shore power or a generator.
All RVs come with CONverters while few come with INverters.
09-25-2016, 10:57 PM
AGM battery works great
I have an AGM battery in my camper for 7 months. It is great. Just use the disconnect switch when stored. It will keep the charge for 3 months and lose maybe 5% of reserve. There is no maintenance.
__________________________________________________ ____________________________________________
2016 Rockwood Minilite 2503 S
2015 Ram 1500 Quad Ecodiesel
09-25-2016, 11:30 PM
AGM batteries have slightly different charge characteristics then standard wet cells... that being said, I have used an AGM as a start battery in my tow vehicle for nearly 4 years and it worked great... however this spring I changed tow vehicles and pulled out the AGM to use as an extra battery around the garage... my regular wet cell battery charger/maintainer did not seem to keep it charged all the way and I thought it was going dead on me.
I finally bought a specific AGM charger/maintainer early in the summer for about $60... for several days the AGM charger only showed a 50-75% charge, but this AGM charger/maintainer also desulfates and after about a week the battery finally showed 100% charge... I use the battery to power a portable hitch mounted winch setup that I sometimes use when cutting down the dead ash trees we have around the house. After I am done with it the AGM goes back on the charger/maintainer, where after an overnight charge it goes back to 100%.
My take is after this experience is that AGM are tough batteries, but when down for a season like over the winter in an RV, a specific AGM charger will probably get you the most out of the battery.
just my opinion based on my experiences with one AGM that is now almost 5 years old
2014 Shamrock 183
09-26-2016, 06:31 AM
I have AGM batteries in both vehicles and our TT. Definitely a tough battery. The oldest is 6 years old in a '04 Jeep Grand Cherokee.
Happy Camping!
2012 Ram 1500 Crew Cab 5'7" Bed
4 X 4 Engine 5.7L Hemi Gear 3.92
Airlift 1000
2015 2809W Windjammer (Diamond Package)
Husky Centerline WDH
09-27-2016, 10:43 AM
Newbie
We're looking at an AGM battery for our 2104s. What are the dimensions of the battery that comes standard with the Mini Lite? We're over 200 mi away from the TT right now and want to be sure what we buy here will fit in the battery box when we take it there.
Susan & Jim
2014 Ford F-150 (white, of course!)
2015 Rockwood Mini Lite 2104s
09-27-2016, 12:59 PM
SusanO, there are two standard size battery boxes used on most TT's. The small one uses a group 24 battery. The larger box can hold either a group 27,29 or 31 battery. Two side by side small boxes are possible but there is not enough room for two side by side large boxes, at least on my 2504s. If you just want to run 1 battery upgrade to a group 31. The larger box only costs like $10-12 dollars. Jay
10-01-2016, 06:32 PM
One problem with AGM batteries is that if they are ever fully discharged the converter on the RV will not be able to recharge them.
I found this out the hard way when I left my refrig on DC power on a previous trailer once thinking the solar panels would keep the batteries charged up.
The AGM battery would not accept a charge.
I took it back to Batteries Plus and they had to charge it at a very high rate in order to bring it back to life.
10-01-2016, 07:41 PM
That has been my experience as well. When I have had one get drained right or wrong I use jumper cables from the tv for about 10 minutes and then the charger took over from there.
Sent from my iPad 18 using Forest River Forums
2017 Flagstaff FLT21DS
2011 Tundra Platinum, 5.7l, 2WD, Firestone bags...
