Old 09-23-2016, 09:15 AM   #1
Agm battery
Hello can agm batteries be used with the rockwood mini lites? Will the inverter work? Charging ?
Thx
winstmk is offline   Reply With Quote
Old 09-23-2016, 10:33 AM   #2
Nurek's Avatar
Why wouldn't an AGM battery work?
Perhaps you could Google that information yourself to find how it directly affects TT usage.
Choosing the Best RV Battery: Which is Right for You?
2011 Nissan Xterra
2016 Rockwood MiniLite 2306 First ever RV.
Nights Camped 2016 [24]
Nights Camped 2017 [tbd]
Nurek is online now   Reply With Quote
Old 09-23-2016, 10:35 AM   #3
I have , not finding much. Thought I read some where that the inverters would not charge them correctly.
Thx for reply
Old 09-25-2016, 06:23 PM   #4
BruceM's Avatar
I have 2 AGM's on our 2109S, one up front and one on the rear bumper.
2015 Rockwood MiniLite 2109S
2012 Nissan Frontier V-6
Blue Ox SwayPro hitch
BruceM is offline   Reply With Quote
Old 09-25-2016, 06:32 PM   #5
Ford Idaho's Avatar
My lite has a G27 AGM, heavy beast but it does what I need it to.
Ford Idaho is online now   Reply With Quote
Old 09-25-2016, 09:59 PM   #6
camaraderie's Avatar
AGM charging routine is generally very close to the wet cell routine and as long as you have a modern 3 or 4 stage charger, they should present NO problem. They DO like to be treated well though for best life so:
1. Always charge them fully after use. If you don't charge them to 100% their capacity will deteriorate over time.
2. Don't leave them unattended and plugged in at float charge levels for weeks at a time. Charge them fully...then disconnect at the negative terminal if you won't be visiting for a while. The SELF discharge rate is about 1/10th of the wet cell rate and they can sit for a LONG (6 months+) time unattended and hold their charge.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 09-25-2016, 10:28 PM   #7
Moderators' Assistant
bikendan's Avatar
Thx
Rockwoods don't have INverters, unless a previous owner installed one.
They do have CONverters, which recharge the battery when plugged into shore power or a generator.
All RVs come with CONverters while few come with INverters.
Dan-Retired Firefighter/EMT
2016 PrimeTime TracerAIR 255, pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 09-25-2016, 10:57 PM   #8
AGM battery works great
I have an AGM battery in my camper for 7 months. It is great. Just use the disconnect switch when stored. It will keep the charge for 3 months and lose maybe 5% of reserve. There is no maintenance.
__________________________________________________ ____________________________________________
2016 Rockwood Minilite 2503 S
2015 Ram 1500 Quad Ecodiesel
campbuzz98 is offline   Reply With Quote
Old 09-25-2016, 11:30 PM   #9
rsdata's Avatar
AGM batteries have slightly different charge characteristics then standard wet cells... that being said, I have used an AGM as a start battery in my tow vehicle for nearly 4 years and it worked great... however this spring I changed tow vehicles and pulled out the AGM to use as an extra battery around the garage... my regular wet cell battery charger/maintainer did not seem to keep it charged all the way and I thought it was going dead on me.
I finally bought a specific AGM charger/maintainer early in the summer for about $60... for several days the AGM charger only showed a 50-75% charge, but this AGM charger/maintainer also desulfates and after about a week the battery finally showed 100% charge... I use the battery to power a portable hitch mounted winch setup that I sometimes use when cutting down the dead ash trees we have around the house. After I am done with it the AGM goes back on the charger/maintainer, where after an overnight charge it goes back to 100%.
My take is after this experience is that AGM are tough batteries, but when down for a season like over the winter in an RV, a specific AGM charger will probably get you the most out of the battery.
just my opinion based on my experiences with one AGM that is now almost 5 years old
2014 Shamrock 183
2014 RAM 1500 SLT Crew Cab HEMI 3.21 8 Spd 4X4
Old 09-26-2016, 06:31 AM   #10
ov845's Avatar
I have AGM batteries in both vehicles and our TT. Definitely a tough battery. The oldest is 6 years old in a '04 Jeep Grand Cherokee.
Happy Camping!
2012 Ram 1500 Crew Cab 5'7" Bed
4 X 4 Engine 5.7L Hemi Gear 3.92
Airlift 1000
2015 2809W Windjammer (Diamond Package)
Husky Centerline WDH
ov845 is offline   Reply With Quote
battery
