06-19-2014, 12:47 PM
Air bed drawer doesn't open?
Hi there all,
I just picked up my 2014 8282WS and can't wait to get it out camping. We have one issue, the sleep and store air sofa drawer will not come out more than 6". Anyone else have this problem or an idea on how to fix it. It looks like one side of the slide is hitting a hard stop.
Cheers,
06-19-2014, 01:12 PM
Originally Posted by Scubaboy323
Hi there all,
Cheers,
Just a guess, any chance there is a spring loaded catch to release the mechanism?
06-19-2014, 01:32 PM
Open the bed, then you will be able to see down along the drawer slides. Mine will stick occassionally, usually going in, a stern push will get it to go. A screw may have backed out in one of the slides.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
06-19-2014, 06:09 PM
thanks for the suggestions, there is no spring catch though. I have opened the bed and tried from behind to look for any block. nothing there, most likely a screw head blocking but the 2 that could be culprits will not tighten or loosen just spin.
2014 Rockwood 8282WS
2012 SCREW F150 5.5box
3.5L EcoBoost, 3.73 Axle, HD/Max Tow Package
Reese Revolution 16k pro
8 night camping 2014
06-19-2014, 06:56 PM
Mine did same thing looked at the bottom of couch and found it was a bolt had loosened up when you shifted things back to alignment and tightened it up worked fine. Can't tell you exactly what to tighten but it was kind of obvious if I remember right.
Think about things before you do them make life easier not harder.
06-19-2014, 07:01 PM
thanks Mark,
Do you mean a bolt on the couch assembly or the slide for the drawer?
cheers,
06-19-2014, 07:54 PM
thanks Mark,
cheers,
Can't remember which ever one it was but it was under the couch and I think it was on the slide. Flip it up and take a look was really easy to spot on mine.
06-19-2014, 08:07 PM
Cyber Phrenologist
Even when it works "right" it still must be aligned perfectly or it will tend to jam. Had mine since 2008. Doesn't get better, doesn't get worse. Don't put anything heavy in there, just blankets, pillows and such.
KU4OJ
2008 (or is it 2009?) Rockwood 8280SS - 2022 F-250 7.3L
06-19-2014, 08:18 PM
Ok I will have a look and re-post. You are dead on Radio, the drawer is just flimsy plastic, we only plan on keeping the sheets for the bed in there.
cheers,
06-20-2014, 07:14 AM
Radio is right they do tend to jam even when aligned correct but if not aligned won't open no matter what. Mines made of wood, not plastic therefore it might be a little different.
06-20-2014, 07:47 AM
Boy I forgot about that (Issue) it was so long ago! When ( New) our (Unloaded Drawer) stuck 1/2 way out, (I took care of that)! Do you know how many (Ball Bearings) are in each slide slide? I Do (10,000) all over the floor! So off to H/D and buy a Good Set of drawer slides,and now smooth as Silk! Youroo!! Our Air Bed Drawer is (Plastic)!
06-20-2014, 08:28 AM
Probably still finding the occasional one hidden, I've got a bedroom drawer I need to replace the slide in hope I don't have it fall apart like that.
