Old 07-19-2013, 05:31 PM   #1
rbrumm's Avatar
Air Conditioning
Ok. This is really the first time I have gotten a chance to use the air conditioner. It is only 85 degrees out and I can't get the inside down to even 75. Does anyone else have air issues? This is a new trailer. My old one would freeze me out.
2011 Ram 1500 Outdoorsman
2014 Rockwood 2909SS Emerald Package
rbrumm is offline   Reply With Quote
Old 07-19-2013, 05:40 PM   #2
lswartz's Avatar
There is something wrong, it should be able to drop it by 10 degrees easily.
2021 Rockwood Mini Lite 2109S
2010 Toyota Tundra 4WD
lswartz is offline   Reply With Quote
Old 07-19-2013, 05:46 PM   #3
The Rockwoods are very poorly insulated, and it takes some time to cool them down. How long has you air conditioner been running?
bakken is offline   Reply With Quote
Old 07-19-2013, 06:23 PM   #4
A quick and easy check you can make is the TD or temperature differential test. Get a thermometer and measure the air temperature of the air coming out of the AC. Note the temperature. Now measure the temperature of the air going into the return side of the AC. There should be at least a 20 degree difference. If not, your AC is not working to capacity.
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 07-19-2013, 09:31 PM   #5
rambilt's Avatar
Your a/c may not be working properly. I'll have it checked.
rambilt is offline   Reply With Quote
Old 07-21-2013, 02:41 PM   #6
rbrumm's Avatar
Worked fine the rest of the weekend. Must have just needed time. I would have thought that a couple hours being on it would have cooled down, but it took longer.
