Old 03-27-2013, 07:15 AM   #1
f150k's Avatar
? air ride pin box
We just bought a Rookwood 8282WS 5th wheel, great trailer. The question, does anyone know of an Air Ride pin box that will work, it came with what looks like a 10K Revolution Sidewinder pin box. I have always had air ride boxs and do not need the sidewinder feature as I have a F350 long box truck. My Trailair box is to wide to mount to the new 5er.
f150k is offline   Reply With Quote
Old 03-27-2013, 07:18 AM   #2
TURBS's Avatar
Fyi you can use the revolution just like a normal pin box.
You just have to lock it at the pivot via bolts and remove the wedge if it even has one.
As to the trail air I can't help.
Turbs
Old 03-27-2013, 07:38 AM   #3
f150k's Avatar
Yes, I have the pin box lock, its just I would like an Airride box. Like the way they pull.
Old 03-27-2013, 08:13 AM   #4
TURBS's Avatar
Your dealer didn't have any suggestions?
Or did you buy it privately?
Get the pin box numbers and call trail air as I'm sure they'll have a replacement for you.
Turbs
Old 03-27-2013, 08:17 AM   #5
Dave_Monica's Avatar
The Rockwood/Flagstaff 5W used to come with a Lippert 1621 pinbox...that's what's on mine. You can look at any air loaded or rubber-mounted pinbox that lists it as a replacement for the 1621 pinbox.
Dave
Old 03-27-2013, 10:16 AM   #6
Owner/Operator
RodeoGeorge's Avatar
I researched Air Ride Pin Boxes, looking specifically at the Lippert Trailair Tri-Glide. I found a source to be:
Ultra-Fab Trailair Tri-Glide Air Ride 5th Wheel King Pin - Lippert 1621 - 18,000 lbs Ultra-Fab Products Fifth Wheel King Pin UF35-946229
When I inquired exactly which one would replace the Revolution on my 8289WS, eTrailer replied that I would need to give them the Part Number off the existing Pin Box to ensure an exact fit.
I'm dragging my feet on changing the Pin Box until I see how much stress my one ton truck is going to exert on the coupling. That amount of money will cover a lot of other mods I'd like to do.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 03-27-2013, 11:06 AM   #7
f150k's Avatar
Just got off the phone with Reese tech, told me that at this time there is not an air ride to replace for OEM pin box on the 8282WS. The 10K Revolution Sidewinder is a special unit made for them. Tech said that Lippert maybe working on an air ride but as of now there is no replacement. Bummer
Old 07-30-2013, 05:40 PM   #8
I just called Lippert and reese neither was of much help there is no plans to make trail air etc for the reese revolution at this time what a bummer. so much for customer service seems they don't care
morriston57 is offline   Reply With Quote
Old 07-30-2013, 06:53 PM   #9
Owner/Operator
I can't begin to tell you how much time I've put in on finding an air ride box for my 8289.
Did basically the same thing as several others and called eTrailer, Lippert, Reese, and Ultra-Fab. They all point the finger in the others direction stating that the Pin Box we have on our Rockwoods is a "special build", but nobody seems to be able to tell me WHO builds it.
With our Pin Boxes being only 10" wide, none of the existing Pin Boxes will fit.
I'd go to an air ride hitch, but having a hauler with the B&W Ball and Companion Hitch is not possible.
If we all keep looking and calling the above suppliers, maybe they will get the hint that the demands is there, but that might be wishful thinking.
RodeoGeorge
