Old 07-03-2019, 01:10 PM   #1
Alignment of dometic 300 toilet
We have a 2506s mini light, the bathroom has a angled wall but they installed the toilet square to the outside wall. So there is no leg room to sit square on the toilet. It needs to be moved to a 45 degree. Has anyone done this yet. I may replace it with a 310 or 320 model. Click image for larger version
Rivasiuk is offline   Reply With Quote
Old 07-03-2019, 01:25 PM   #2
PPST Wannabe
kenandterry's Avatar
I can see your see problem from the picture, and the wording.
When you remove the toilet from the floor bolts, youíll see how they are located in relation to the positioning of the plastic collar attached to the floor.
As you stated, youíd like to reposition the toilet parallel to the angled wall....45 degrees as youíve mentioned. It doesnít matter if you mount a 300, 310 or 320 model, they all attach by bolts in the same position. What matters......if you decide to go with the 320 elongated bowl, is there enough room behind the center of the throat of the waste tank pipe in the floor. The 300 and 310 have the same dimensions front to back, but the 320 needs more clearance room at the back of the bowl.
Measure twice......
Buy once.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 07-07-2019, 06:16 AM   #3
frank4711's Avatar
I replaced my 300 with a 310 ... so I have seen how it attaches it will depend the angle of the collar attached to the floor ... on my camper I was able to turn the toilet to the angle I needed before I tightened it down ... it is simple to do
Frank & Cindy *** Rockwood Ultra Lite *** 2019 Ram *** Remi & Sage traveling Pomskies *** TST 507 TPMS *** B&W Patriot 18K *** 3.92 axle *** Goodyear Endurance *** 32 days camped 2019 *** Predator 3500
frank4711 is offline   Reply With Quote
Old 07-07-2019, 07:07 AM   #4
nomad297's Avatar
If you want to rotate the toilet a little and you find that there’s not slots in the closet flange that work just right for your closet bolt placement, buy a couple spanner flanges. Put your closet bolts in the flanges, then screw the spanner flanges right through the plastic closet flange and into the floor.
Here’s a link to a spanner flange on Amazon: https://www.amazon.com/American-Valv...gateway&sr=8-6
Bruce
nomad297 is online now   Reply With Quote
alignment, dometic
