Old 05-02-2016, 08:45 AM   #131
If all W/J-V-Lite owners with Slides on 1 side really notice when Slides are Deployed,they are LOW on that side if starting out Level! They Need a little Boost Up on the Slide side! Youroo!!
Old 05-02-2016, 08:51 AM   #132
I have 2 slides on one side. Difference between slides out/in is significant.
missing_link is offline   Reply With Quote
Old 05-02-2016, 05:17 PM   #133
MainelyUS's Avatar
Just landed at James Island CG Charleston SC ....follow my recommendation #128...both slides are deployed and the bubble is still between the lines s2s & f2b.:thumbup:
2015 Windjammer 2618VS (Hibernating)
2016 Silverado 2500HD Z71 6.0L 4:10 gears w/max. tow package
Reese Strait-Line WD
MainelyUS is offline   Reply With Quote
Old 05-04-2016, 08:09 PM   #134
tuckerdog1's Avatar
Good & bad on 1st shakedown trip
Took a short trip to Lake Georgetown to get a feel for how well things work in our new TT. The good news is everything about this trailer is what we hoped it would be. All systems work as they should. Very comfortable for two people and a couple dogs.
The bad was the condition of the site at the lake. It was overgrown with foxtails. Bad enough just walking around the trailer would result in a dozen sticking in my socks. But then one of the dogs got one in his eye. Off to the vet and adios $100. No way we could bring the dogs back there. So a 3 day stay turned into a 1 day stay.
Tuckerdog1
ID:	106913   Click image for larger version
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB
2016 Windjammer 3029W Platinum
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
tuckerdog1 is online now   Reply With Quote
Old 05-04-2016, 08:22 PM   #135
MCTroy
TuckerDog - nice looking rig. We like our WJ with the tan exterior but we have a bright blue Ram. We got the truck before the trailer. I like your white trailer and tow. sorry about the site being weedy though.
2015 Windjammer 3029 Diamond Edition
2011 Ram 5.7 hemi
Ohio River Rat
2016 camping: Lost count, but never enough.
2017 reservations made!
MCTroy is offline   Reply With Quote
Old 05-04-2016, 08:25 PM   #136
Capt. Mike's Avatar
I do, too. I have to be about 1.5" to 2" high on the driver's side before the slides (both on drivers' side)are extended. Doing it that way, I'm generally pretty darn close to level when the slides go out.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
“It's not how old you are, it's how you are old.”Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is online now   Reply With Quote
Old 05-04-2016, 08:28 PM   #137
MCTroy
[QUOTE=youroo;1182310]If all W/J-V-Lite owners with Slides on 1 side really notice when Slides are Deployed,they are LOW on that side if starting out Level! They Need a little Boost Up on the Slide side! Youroo!!
Youroo -
Our WJ isn't usually too unlevel with all 3 slides out if the site is level to begin with. But I bought the Anderson levelers to use as needed. We tried them while at home so we knew how to set up on a site that may not be as level as we are used to on our seasonal site. no luck. We didn't get the trailer up on both on of them. In your photo, did you back up on the rear level and then pull up on the front one? How did you know where to put the front one? and what about the tire that isn't sitting on the level? We didn't like part of the tire just suspended between the levelers.
I am wondering if we are doing this wrong or am I just over thinking this?
Thanks for your posts they are much appreciated!
2011 Ram 5.7 hemi
Ohio River Rat
Old 05-04-2016, 08:51 PM   #138
tuckerdog1's Avatar
MCTroy-Thanks for the kind words. Had this truck before the trailer as well. The trailer was already in stock at the dealer, so no real choices for me to make. However, it's pretty much just the way I'd have ordered it if I was building from scratch. Just lucky the color was a match for the truck. As I mentioned in an earlier post, was not in the market for a new TT. Went to the dealer for a state inspection on our other trailer. DW was poking her head into trailers while I was hanging with the inspector. Somehow before we'd left, we had a new trailer. This is sooo much nicer than what we had before.
Correct me if I'm wrong, but isn't color the only difference between the Diamond & Platinum packages?
Tuckerdog1
Old 05-04-2016, 09:14 PM   #139
tuckerdog1's Avatar
[QUOTE=MCTroy;1185476]
Youroo -
Haven't tried this with our new WJ, but it worked well with our previous trailer. I bought 1 Anderson leveler & 1 of the Anderson flat tire changing things. It looks like a leveler, but has a couple inches more lift, so you can get a flat off the ground. Our earlier trailer did not have enough space between the tires to fit a leveler in there. The WJ looks to have even less space between the tires. So when I put the flat tire Anderson under the forward tire and pulled forward until level, the rear tire would sometimes come off the ground. Still couldn't get the regular leveler in between the tires, so to give support to the hanging rear tire, I'd hammer the leveler in from the rear with a rubber mallet. This supported the rear tire, and acted as a chock. To get it out when time to leave, just pulled forward a bit until the pressure was off, removed the leveler, then backed off the front leveler.
Old 05-05-2016, 06:00 AM   #140
MCTroy
Tuckerdog1
We were told the wood trim and upholstery was an upgrade too. I have noticed some don't have the padded covers over the doors and windows. Just a few changes like that. We just bought the one we liked. My DH actually picked our WJ out. I didn't care so long as I got that big closet in the V! I am a pack rat!
2011 Ram 5.7 hemi
Ohio River Rat
windjammer
