12-21-2018, 10:48 PM
#621
Thanks for the Info Sir.. I al really leaning towards the EEZ Tire, it seems to come up on the top of the pile everywhere I look..
I will likely need the repeater too but it comes with one so Im good !
Thank You Sir.
2019 Montana 3121RL Anniversary Edition
2016 Ram 2500 Cummins
12-22-2018, 06:53 AM
#622
Originally Posted by Jay2504
kc5mhb, Carolina Carports did my carport also. Can’t say enough good things about them. Done in one evening amd part of the next day. If I may ask who’s crew did yours? Jay
Originally Posted by kc5mhb
CCBR.net Richard. He had a 3 man crew come in from Texas to set it up. They work the Louisiana area and the main guy said they do several a day. Nice guys and hard workers.
Jay2504
kc5mhb
Is your carports on concrete or are they on gravel pad?
2017 Rockwood windjammer 3025w
12-22-2018, 08:06 AM
#623
Originally Posted by nomad297
With nothing else to do but sit around the house and wish I was out camping in my Windjammer, I thought it would be fun to start a thread to see how many other Winjammer owners frequent this forum. I am interested to know which year and model you have and how happy you are with it. Have you had any problems?
We have a 2016 3029W and love everything about it. The only problem we had was with the iRV 66 entertainment system, but that was so efficiently handled and easily replaced, I dont really consider it a problem.
Bruce
(Captain of the Windjammer cheerleading team)
We bought a 2014 Windjammer 2809 in 2015. Love the big couch in the V nose. We had problems with the countertops but they were replaced. The only reason I will not get another Windjammer is the fact that the two slideouts are on the same side which makes it difficult to be level, when parked at the same place for several days...it tends to lean on that side. Other than that, it's a Rockwood so it's a good trailer! Merry XMass to all!
Grangalo
2014 Rockwood Windjammer 2809W Diamond package.
12-22-2018, 08:16 AM
#624
Georgia Rally Coordinator
Our first V-lite was set up like yours with two slides. The way to solve the leaning on the side with the slides is even if tt is level starting we would put down a 2x6 board on that side and back on to it. Then unhitch then make sure level front to back, put down the stabilizer jacks then run slides out. You will find that the camper will settle in to almost level and a slight bit high on the slide 0ut side when extended. Worked great and solved that issue. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
12-22-2018, 08:37 AM
#625
I set up high on slide out side, extend the stabilizers on that side, extend the slides, then the stabilizers on the other side. Stays level after that.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
12-22-2018, 09:55 AM
#626
Originally Posted by hoogy
Jay2504
kc5mhb
Crushed concrete.
2019 Flagstaff V-Lite 30WTBSV
2000 F250 CC SD V10 4X4 8' bed, 4:30 gears, SCT X3
2007 Mustang Convertible V6 - Lots of GT mods
1965 Mustang Coupe I6, 3 spd. manual
1996 Cadillac Fleetwood Funeral Car (Ghostbusters ECTO)
12-22-2018, 10:00 AM
#627
X2 on putting a board down. I use the plastic stacking blocks. I have one of those electronic levelers that tells you in inches what you need to make it level. Works great.
12-22-2018, 01:07 PM
#628
Anybody with a Windjammer done a disc brake conversion ? Been scratching my head on it and I know lots of the fiver folks are doing them. I was not sure with our torsion type axles if they were as easy to do etc, but I really like the idea of moving up to the disc brakes. Got the good tires on her now. Would love to take that next step !
12-22-2018, 01:32 PM
#629
You are definitely going to spend some money doing that. Not saying that it can't be done though. https://performancetrailerbraking.co...hoCqfgQAvD_BwE
Kits start around $1600.
12-22-2018, 02:00 PM
#630
If you think about it, not that expensive even if you have it done. About ($2500) I was lined up to have them installed on my v-Lite but ran into a snag. My camper only came with 4000# axles and there is no kit available from those folks. They even came to the house and to do the install after many conversations and thought it could be done but low and behold found out the backing plates would not fit. From what I've seen on the Windjamers they have the 5000# axles and the conversion for the tork flex axles can be done. I'm still hoping they come up with a kit for mine as I've heard nothing but good results after the installs. Later RJD
Days camped 2019 62
12-22-2018, 05:52 PM
#631
My carport is on crushed packed gravel. I am gradually installing 16”x16” pavers. The last space between the uprights is enclosed to make my shed for the mower ect. I put a plywood used for sub floors in there. When you pull up it looks like there is a garage behind the carport, big door and everything. The only problem is the “garage”;is 52 inches deep! Jay
12-22-2018, 08:53 PM
#632
Thanks Sir, I will check out this link and see what I come up with !
12-22-2018, 08:55 PM
#633
Your V Lite is longer than mine, since Im only 31 feet. Seems like we would have the same axles, but you obviously know since you actually had them come out and try to do the install. Give it some time and they will likely have a kit that will fit it...
12-22-2018, 09:17 PM
#634
Just look to see what your axle rating is. If 5000# your good to go. Later RJD
Days camped 2019 62
12-27-2018, 06:37 PM
#635
Any Georgia folks on here camping at Hard Labor Creek right now ??
My son says a big V Lite pulled in just below them this morning at HLC.. Hes in a Jayco 5th wheel..
Thought it might be one of you folks !
12-29-2018, 05:44 PM
#636
We are making our maiden voyage in our 3006WK. We have the Diamond pack, and the awning seam that’s about 12” from the bead where it attaches to the trailer is leaking all the way down the seam. I’m assuming that is a faulty awning because it wasn’t sealed. It has the metal cover when the awning is rolled up. Anybody else have that problem?
2017 Ford F-250 Super Duty 6.7 PowerStroke
2017 Rockwood Windjammer 3006WK
12-29-2018, 08:03 PM
#637
MCTroy
Congrats on your first trip. That awning seam leak is a common problem. The seam needs to be sealed. We bought a spray from our dealer and it did a great job. Spray it once each year and done. I think it was a silicon spray. Others on here will know for sure.
12-29-2018, 08:10 PM
#638
There have been several reports on this and not just on your model.
Mine leaked and I sealed it by rubbing a very light coat of clear sealer (ProFlex not silicone) along the seam. (just enough to fill the stitch holes)
Others have reported using a tent seam sealer.
Finally, some have reported the seam not leaking after being weathered a bit.
12-30-2018, 09:37 AM
#639
When you used the ProFlex, what did you do to prep the fabric before applying it? Also, did you apply it on both sides or just one? How many seasons has this held up for you?
Bruce
12-30-2018, 12:29 PM
#640
Bruce
Mine was only a few weeks old so no prep.
I used my finger and just pushed a little into the seam from the top only.
I extended the awning about a foot and worked off a ladder.
I used the ProFlex very sparingly. It could be easy to gob too much on so be cautious.
