Old 04-12-2022, 10:21 AM   #901
Trim beside rear entry door.
This black trim which I think covers screws is bulging out loose right midway up near where the entry door latch is.
I can push it in but it just pushes right back out. I’d say it’s an area about 6 inches tall and right in the middle it’s bulged out prob 3/8 inch. Can’t figure why or how to get it back in. I don’t see anything holding it on or anything it snaps into. Any ideas? I’ll try to add a picture. Don’t know how long it’s been like that but so far it hasn’t allowed any water to get in but I don’t want it to start.
Rhizzlebop is offline   Reply With Quote
Old 04-13-2022, 03:10 AM   #902
MCTroy
The trim piece issue maybe commonto other trailers. You may want to post your question and a picture in a general forum for more responses.
2015 Windjammer 3029 Diamond Edition
2018 Ram 2500
Ohio River Rat
MCTroy is offline   Reply With Quote
Old 04-13-2022, 07:32 AM   #903
Here’s a couple pictures of the door trim issue.
ID:	271450   Click image for larger version
Old 04-25-2022, 11:28 AM   #904
Hey all-
Quick question on the windjammer awning.. we have a 2015 3008W we purchased last year and it’s the first time we used the awning.
I notice when I closed the awning, the rails didn’t seem to line up (sit completely flush at the top of the rail) I’ve attached a few pics..
Is this normal or does it need an adjustment?
ID:	272089Click image for larger version
ID:	272090Click image for larger version
RVngFam is offline   Reply With Quote
Old 04-25-2022, 12:31 PM   #905
tuckerdog1's Avatar
The rails are just along for the ride. They're gonna stop when the awning rolls up as tight as it's gonna go and stops. It does look like your awning might be a "little" uneven on the rollup. Note at one end, the aluminum cover completely covers the end cap, and on the other, it looks like about an inch or so of awning material is exposed. Might be causing an uneven rollup. No idea how you'd adjust that. YouTube might be your friend there.
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB
2016 Windjammer 3029W Platinum
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
If you don't punish your children, life will.
tuckerdog1 is offline   Reply With Quote
Old 04-25-2022, 02:39 PM   #906
MCTroy
Hi RVngFam. Congrats on the Windjammer. I like the white exterior.
Our awning arms rolled up a lot worse than that and were fine. We had a gap about 2 inches on the front arm. I put a wide piece of velcro on it as a security to slow it down if it tried to unroll. Over several trips it never unrolled. We had new motors put on both awnings this year. The guy installing them gave the awning arm a good shove and it rolls up a lot better! Sorry I did not see exactly where he did his adjustment. I agree with Tuckerdog that you should be fine.
Happy Jamming!
2018 Ram 2500
Ohio River Rat
Old 04-25-2022, 08:53 PM   #907
Happy Jamming!
Thanks!
We’re absolutely loving the Windjammer!!
When you say gave the arm a good shove, did he move it while the awning was closing?
Old 04-26-2022, 05:52 AM   #908
MCTroy
The awning was stopped about 3/4 the way in and then he pushed the arm. It winds in tight now. I think the new motors help too but those weren't cheap. Good luck!
2018 Ram 2500
Ohio River Rat
Old 04-26-2022, 06:28 AM   #909
Georgia Rally Coordinator
aceinspp's Avatar
The awning is not rolling up properly causing the arms not to completely come to rest when fully retracted as indicated by your pics. I had the dealer adjust mine don't know what he did. This happen on my 2015 V-Light. As mentioned you can try to shove it over when rolling up and it may help. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Old 04-27-2022, 06:31 AM   #910
Native Texan's Avatar
https://youtu.be/Y9aQ_YFKVqw
Have the same issue with my awning, going to try this fix this weekend. Not sure how easy this will be with a large awning but it worked in the video……:
2015 Flagstaff V-Lite 30WFKSS
2013 GMC Sierra 2500 HD Duramax
Native Texan is offline   Reply With Quote
Old 05-01-2022, 12:19 PM   #911
It worked. My awning took a little more persuasion since it has the built in cover and is heavy. Couldn’t budge it just using my hands but with some channel locks and a rubber mallet on the far end I got it to move enough that the awning rails line up perfectly now…..
Old 05-01-2022, 05:08 PM   #912
MCTroy
When all else fails, use a rubber mallet. Congrats
2018 Ram 2500
Ohio River Rat
windjammer
