Old 02-26-2016, 11:55 PM   #81
Hi we bought a 2015 30 wikss flagstaff. This is the same floor plan as the windjammer 3025. Pulled the C load range tires off after only a couple of 100 miles. did not like how the trailer towed and behaved behind my F350 four door dully with 8' bed. The tires were right at the max load they could carry and looked like they were squatting under the weight of the trailer. New tires don't have that squatting look. Bought Carlisle ST load range E tires. run the pressure at 75-80 psi. bought them at discount tire last spring for around 500.00 balanced and installed on TT. I asked for the newest born on date which was 2-3 months old for all 4 tires. They had a set that was almost 1 year old in the shop. If I did not ask for the newest tires they would probably have sold me the 1 year old ones.
Hope this helps Tim
TimVWulp is offline   Reply With Quote
Old 03-08-2016, 08:22 PM   #82
ov845's Avatar
We love our WJ. Had some minor issues, no big deal. Just installed Progressive 30A EMS.
Happy Camping!
2012 Ram 1500 Crew Cab 5'7" Bed
Engine 5.7L Gear 3.92
Airlift 1000
2015 2809W Windjammer
Husky Centerline WDH
ov845 is offline   Reply With Quote
Old 03-09-2016, 10:52 AM   #83
Pyromedic's Avatar
Anyone with the 3006 have a TV mount on the outside and in the main bedroom? If so, where is the mount located on the wall outside and in the bedroom
Pyromedic is offline   Reply With Quote
Old 03-09-2016, 02:35 PM   #84
We don't have an outside TV mount but want to share to be careful when mointing because our screws were too long for the bedroom mount and we accidentally punched through the back of the trailer. (We have a 3008)
dkkirkland is offline   Reply With Quote
Old 03-09-2016, 02:45 PM   #85
nomad297's Avatar
This is what I use to mount my 42" 20lb TV to the outside of my Windjammer. I put it wherever I want, whenever I want.
GOstik Products Flat screen TV Suction Cup Mount | GoStik
Bruce
Old 03-09-2016, 07:08 PM   #86
gectisme's Avatar
We don't have an outside mount either, I don't think we would use it anyway but it is kind of funny they run an antenna or cable connection there but don't put a mount.
I asked about the bedroom option and no one on the forum got back to me. I then sent an email to Forrest River asking where does it mount and this is the answer I got back:
"If backing for tv mounts are in your unit, a sticker will be labeled saying tv backer in the location where the tv will go."
Ours didn't have a sticker so I asked if he could tell where they would put the backing and never got an answer. I changed my mind and probably won't install one in the bedroom so I didn't pursue it.
2016 Windjammer 3006WK
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, (not really used, left over from our truck camper). Equalizer E4 1.4k/14k WD Hitch. TST 507 TPMS. Furrion FOS48TA Observation Camera. Garmin RV-760 GPS. Honda 2000i Genny, PI EMS-PT30C.
gectisme is offline   Reply With Quote
Old 03-09-2016, 09:39 PM   #87
MCTroy
Our 3029w has a bedroom tv. It uses a ceiling mount under the hanging cupboards. Not sure how your bedroom is laid out but look at options not on the wall.
We have an outside mount for the same tv too. Just two slots near the electric outlet and the tv slides on it. We can also put the tv on the shelf that slides in by the grill.
We like to sit outside and still catch a nascar race on tv.
2015 Windjammer 3029 Diamond Edition
2011 Ram 5.7 hemi
Ohio River Rat
2016 camping: Lost count, but never enough.
2017 reservations made!
MCTroy is offline   Reply With Quote
Old 03-09-2016, 09:46 PM   #88
Dazed & Confused
M&K Hoffman's Avatar
We have a 3008W, so I cannot answer your question. What I can tell you is that we had a sticker of the wall in the bedroom stating where the backer was located. As far as outside goes the cable outlet is located directly below where that little outside table hangs and the salesman said we could set a TV on that.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 04-19-2016, 10:17 PM   #89
tuckerdog1's Avatar
Today, took our Jayco X213 to the dealer we bought it from, for a state inspection. While I was hanging with the guy doing the inspection, my wife was poking her head inside new trailers. Next thing I know, we've bought a 2016 Windjammer 3029W.
How does this happen?
If I'd known, I could have saved the inspection fee.
Tuckerdog1
ID:	105482   Click image for larger version
ID:	105483   Click image for larger version
ID:	105484   Click image for larger version
ID:	105485   Click image for larger version
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB ( Mine )
2015 Genesis 5.0 ( Hers )
2016 Windjammer 3029W Platinum ( Ours )
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
tuckerdog1 is offline   Reply With Quote
Old 04-19-2016, 11:44 PM   #90
Tuckerdog1
Taking wife = big mistake!
That's a pretty big jump, too. A lot more than "two-foot-itis"
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
windjammer
