09-22-2015, 01:02 PM
#21
We also had a flat on our 8281 WS on Sunday. Tires are the Power Tommy's as well. Had a local tire shop replace all 4 tires and upgraded them to 10 ply load range E. Tire guy was amazed that the original tires were load range C and only 6 ply.
I had no idea that the tire was flat, another driver pointed it out. It was hot 101 degrees and the road surface was awful. Never went over 60 mph.
Donna and Bob (retired USAF),
fur babies Casey (mix), Lucy and Loki (standard poodles)
had a 2015 Rockwood 8281 WS - traded for another brand.
2016 RAM 3500
09-22-2015, 01:14 PM
#22
Has anyone reported these tire failures to National Highway Traffic Safety Administration?
09-22-2015, 01:25 PM
#23
I'd be interested to hear what deals folks have got on a decent replacement set of tires, and where the got them installed (rather than installing themselves) and how much they charged for installation.
I only have < 400 miles on our 8281WS, tho' will be doing another couple of in-state trips next month, and another trip up to the FL/AL border around xmas. We do have an 8000 mile road-trip planned for next year tho', so definitely want better tires for that, if not before, and am also wanting to get a TPMS (recommendations welcome).
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
09-22-2015, 01:33 PM
#24
Oh yes
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
09-22-2015, 01:42 PM
#25
I'd also appreciate if anyone can clarify what the ST tire prefix implies ?
I know the load ratings (and most of the 225/75R15's seem to be 102 load ratings, which seems significantly under-rated for a 2 axle fifth-wheel, and the speed rating (tho' I guess C is much lower than I'm used to).
I did spot that TireRack had some
POWER KING TOWMAX STR II
Size: ST225/75R15 117/112L E
which have a much better load rating
Edit: Reading further into description, I guess ST is Specialty Trailer tires (not designed for driving wheels), and these tires are L speed rated (75mph), and E load rated (10 ply, 80 psi max), not sure why they give 2 load numbers).
The listed specs are that they're rated for 2830lb each, 80psi, and are chinese made.
Also found that DiscountTire list some Hartland Radial ST tires, which are 117 load rated, N speed rated (87mph), and E load/ply rated (10 ply, 80psi), and similar spec Carlisle Brand tires. No idea of the reputation of any of these brands
09-22-2015, 01:49 PM
#26
How old (timewise) were the failed/replaced original tires?
09-22-2015, 01:52 PM
#27
The 10 ply Maxxis 8008 st tires that I bought 225/75/15 were $126.00 Ea from Discount tire. The steel valve stems were $4.00 each. I have the tst 507 TPMS with the flow through sensors. Had the wheels balanced with the sensors in place. Discount Tire also included lifetime spin balance and repairs in there price. Bought 5 tires to include the spare. I did not seek any financial relief from FR, maybe I should have but it's been over a year now. I have read on this forum that some have gotten $300.00 from FR towards better tires
Joe & Beverly
2014 8289WS lifted
09-22-2015, 01:56 PM
#28
The tire I had go bad was 8 months old and had about 3K miles on it. It was a bead leak / crumble not a blow out.
Joe & Beverly
2014 8289WS lifted
09-22-2015, 01:58 PM
#29
The plies are usually also given by lettering molded on the sidewall e.g. tread: 2 polyester 2 steel 2 nylon, sidewall: 2 polyester 2 nylon.
Note that the nominal 'ply' rating will not correspond to how many actual plies are in the tire construction. The 'ply' rating is based on some ancient bias ply construction where that number of cotton plies was required to give that inflation pressure burst strength.
DNBINFV: your destroyed tire also shows the signs of severe underinflation running. TPMS: Don't Leave Home Without IT!
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
09-22-2015, 02:02 PM
#30
B & B had exactly the same issue (bead crumbled and parts stuck to the rim when removed). I don't trust how no-name Chinese factories compound their rubber. We live in a long-time tire building (and even longer time rubber compounding) community. Anyone here over 45 knows what good tire rubber smells like and most Chinese tires don't have it (but my Chinese GY Marathons do).
09-22-2015, 02:06 PM
#31
We also have the 8289WS. 2014 that we have had two years now and 14000 miles. Had read about the issues with the OEM tires and so kept a close eye on them and installed a Tire Traker system. With about 9000 miles on them I discovered a crack in three of them. All located on the inside and about an inch from the rim. Tire shop would not do a repair due to the crack. I replaced all four and have had no problems. Those original tires also had trouble holding air. After some "back and forth" with Forest River they reimbursed me $300. Have had a few other minor issues but my experience with FR has been nothing but positive.
09-22-2015, 02:42 PM
#32
Not that I've had any actual issue yet, and I doubt they'd feel like contributing towards new tires as a preventative measure, but how did you contact FR ? Any specific contact person ?
09-22-2015, 02:59 PM
#33
I sold mine on Kijiji - think I got $200. Was up-front that these should not be used on a trailer over about 4000lbs. Hasn't come back on me in a year and a half so I guess the buyer was happy.
09-22-2015, 03:00 PM
#34
Dr Travel
That's it. You have convinced me to replace our tires when we arrive in FL. Thinking of Michelins…best tire I know of.
09-22-2015, 03:10 PM
#35
I believe the higher load rating is for the tire on an axle with one tire on each side and the lower is for the tire on an axle with two tires on each side.
Jack and Jan
Nights camped 2014 - 8 | Nights camped 2015 - 23 | Nights camped 2016 - 24
2015 Ford Super Duty F350 > Blue Ox Swaypro WD Hitch > 2015 Rockwood Windjammer 3008W
09-22-2015, 03:20 PM
#36
How far are you from FL. Might be a bad gamble to wait. IMO
09-22-2015, 03:35 PM
#37
Thanks PhoneDude. I had read earlier in this thread yours were 9 months old and my question was actually directed towards DNBINFV.
The OP (taroth) mentioned his were 9 months old, PhoneDudes were 9 months old.
In another tire failure thread I asked the same question and was told 8 months.
Maybe DNBINFV can let us know the age of his?
Not that it going to help anyone from having a blowout but it 'appears' 9 months to a year is pushing your luck.
09-22-2015, 03:39 PM
#38
I replaced after year, bead crumbled when removed. . Forest River bought mine back for $300 and I got the new ones for $550 so I was happy!
B and B
09-22-2015, 03:59 PM
#39
It's easy to blame the tires. However, after 3 of the tires on my 8289 were unfit for use after 6000 miles, we discovered that those 3 spindles were badly bent so tires were constantly scrubbing the pavement. I'd suggest having the dealer or a reputable alignment shop take a look. Forest River paid for a realignment.
09-22-2015, 05:13 PM
#40
I also have a Forest River 8289ws fifth wheeler. Can anyone out there tell me if the existing rims will except different tires that require 65 psi as opposed to 50 psi. I've read that sometimes the original tires are married to the rims. Thanks!
