Old 09-21-2015, 09:04 PM   #1
Another 8289 WS tire failure
This afternoon after about a four hour trip, the right rear of my Chinese crap tires failed. I checked the tire pressure this morning and inflated it from 45 to the recommended 50 pounds. The trip was on I 85 S and although the road is far from smooth, I did not hit any potholes, curbs or any obvious debris. We do not drive over 60 mph because of the tire rating and our trailer load is well under the rated maximum.
When the tire failed it ripped open the right side slide wire bundle which proceeded to wrap itself around the wheel and locked the wheel. The rim was scraping the pavement with the resultant sparks. Fortunately the outside grill LP supply line was missed, so we didn't have a flaming mess or casualties (we kept the LP on to run the fridge).
We are obviously cutting our trip short since neither main slider will extend and I do not know what the damage to the electrical system may have occurred. I can't wait to hear the weaseling on the warranty. We bought the unit new nine months ago and have put about 7,000 miles on it.
I do not know if Forest River reads this forum, but hopefully they may get a message to put a better grade tire as their OEM. This many tire issues cannot be good for their business. Most people I know would rather pay a little bit more for tires that will withstand normal wear and tear. Placing marginally suitable tires on an RV is just cheap. We were very lucky to avoid being a statistic for a RV fire. Bad tires are DANGEROUS!
As another insult to injury, we attempted to place the ruined wheel on the spare wheel bracket. The ruined wheel would not fit on the spare tire rack. It seems that the spare rim is a different depth than the wheels on the RV. So we had to put it in the basement with the other equipment. More fun as we rearranged the chairs, tables, grill and RV support tools to fit it in without crushing something else.
Photos are attached below from front to rear.
ID:	89507   Click image for larger version
ID:	89508   Click image for larger version
taroth is offline   Reply With Quote
Old 09-21-2015, 09:23 PM   #2
what brand tire was it?
2014 GMC 3500 Denali
2015 XLR 375 AMP
previous 2014 Sierra 360PDEK
previous 2013 Evergreen I-Go
ghostrider is offline   Reply With Quote
Old 09-21-2015, 09:43 PM   #3
Kenny kustom's Avatar
Ordering Samson tires.
12 ply.
2008 F350 CCSB V10
2016 Sabre 36QBOK
Old 09-22-2015, 12:40 AM   #4
DaveSchwartz's Avatar
The middle picture shows the extensive sidewall scuffing that tireman said on another thread is a sure sign that it ran very low pressure or flat until destruction. Although we hear more complaints about the Chinese off-brands, this could happen to any brand so a TPMS is almost required on a trailer because you'll never feel a tire going down like you would on the vehicle you're driving and you'll almost never see it until it starts throwing chunks or sparks (as in your case). While you wouldn't have run over any rocks you saw, you never see the nail or screw that will puncture the tread - like the one I picked up in my TV's rear tire a few weeks ago in Michigan. Fortunately, that only caused a pound-a-day slow leak because it stayed stuck in and not a rapid deflation which could result if it gets spat out.
Sorry for your (material-only) loss. Pretty sure this is going to be an insurance claim and not warranty. Common for it to be upwards of $3000 since it ripped out the wiring and probably also damaged the underside of the slide.
Out of curiousity, on the 8289 is the kitchen slide wire bundle fairly close to the tire? On my 8282 the kitchen slide is on the other side and the bundle is about a foor behind the aft tire and folds toward the back. I hope if I ever lose a tire without advance warning from my TPMS that the gator doesn't grab the wiring bundle like that.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
DaveSchwartz is offline   Reply With Quote
Old 09-22-2015, 05:11 AM   #5
that's terrible. hope it all works out.
curious what size tires and axles are on you trailer?
I would bet they are 225/75/15 c load range and 4k axles.
jgroff is offline   Reply With Quote
Old 09-22-2015, 06:21 AM   #6
PhoneDude 8289's Avatar
My DW was not happy when I had 5 new Maxxis 10 ply tires put on our 9 mo old 5r. Had a tire that would not hold air, pulled it and took it to Discount tire. They tested it, it was leaking where the tire met the rim. When they broke the tire loose from the rim the bead crumbled. Ordered the Maxxis tires, had them installed, balanced and with steel valve stems. I think DW would have been much more upset if we would have ended up like taroth in the first post. I have since added a TPMS to the wheels.
2014 8289WS Diamond pkg
2014 Ram 2500 SB DC TCD
PhoneDude 8289 is offline   Reply With Quote
Old 09-22-2015, 06:34 AM   #7
It's not like everyone on the forum has not been warned numerous times about the factory tires but don't want to upgrade the tires for numerous reasons. I agree the factory should put better tires on the trailers, but it isn't going to happen for those already purchased trailers, so why not just bite the bullet and get better tires BEFORE they blow/disintegrate/whatever and cause major damage that may or may not be covered by warranty/insurance/hip pocket.
Just doesn't calculate in my book.
Old 09-22-2015, 07:38 AM   #8
mcnabbwr's Avatar
Ouch! That's a lot of damage. Hope it works out well for you wether it's a warranty or insurance claim. The good tire in the last picture even looks low, as others have stated replace them all.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 09-22-2015, 08:03 AM   #9
Fred H.'s Avatar
I'm aware of those Chinese tires, have them on my Crusader. But the more I read these horror posts about blowouts, the more I'm considering going to Discount tire and purchasing 4 new tires.
I only have about 2000 miles on them now, but plan on a 1300 mile trip to FL. this winter and back home in April. Wondering now if I'll make it or not!
Such a shame everyone has to worry about this on a brand new RV. Makes me also wonder why there isn't some Highway Safety organization here in the US that would restrict these junk tires from even being imported!
Fred n Wilma
2014 Ford F-150 EcoBoost
2015 Crusader 295RST
Fred H. is offline   Reply With Quote
Old 09-22-2015, 08:15 AM   #10
I only had 10 miles when I replaced the Trail Distress load range C with Goodyear Marathon LRD. Have been from southern Ontario to the Keys (high speed I-75 down, mountainous I-95/85/79 route home), to Chicago, the mountains of north-central PA on terrible roads, various provincial parks. Still hold air perfectly and look new (after washing off the mud).
