Old 01-26-2015, 12:14 PM   #1
Another Electrical Question
I plan to get 2 or 3 AGM batteries so I have the option of boondocking for a few days at a time. I don't intend to boondock for extended periods of time. Maybe 5 days or so at a time separated by weeks in several different developed campgrounds with electrical service. I just want the option to do it if I want to. I also don't want to buy a generator and have to deal with a gas can therefore the reason to charge the batteries in electric supplied campgrounds. If I fall in love with boondocking, then I'll get into it with generator and/or solar etc...but for now, I don't think so.
A quick check on the power I will need from the battery set will be water pump, a few lights, landing gear, stabilizing jacks, cell phone charger, jet pack charger and laptop charger.
Question:
There is a tag on the cord for my laptop charger that says, "125 V, 7 amp". If watts = V * A, does this mean I need a 875 watts inverter just to charge my laptop? I would just as soon not have to get an inverter unless I have too. The rest of the stuff seems to be able to run directly from DC current.
Thanks in advance.
2014 Ford F250 Lariat
2014 Rockwood Signature Ultra Lite 8280 WS
2023 Forest River Rpod model 201
Louisiana before, fulltiming since April 11, 2014
blog--- www.gozatravels.blogspot.com
Darrell is offline   Reply With Quote
Old 01-26-2015, 12:29 PM   #2
Flybob's Avatar
You don't say what laptop, but I think you misread the charger. It is probably more like 1.7A You also forgot to count the CO/Propane sensor in your current demands.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-26-2015, 12:37 PM   #3
I just looked at the charger for my newer lenovo laptop and it is 90W.
You can get laptop chargers that work off 12v you may want to look into this.
One other draw on the battery will be the fridge.
Ontario
Current: 2019 Sunseeker 2290S
Previous (2012-2016): 2012 Vibe 6501
1 Prospector Canoe, 2 Mtn. Bikes & 4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 01-26-2015, 12:49 PM   #4
Also about 1 amp from the frig circuit board.
You might consider a small solar panel -
cadman99 is offline   Reply With Quote
Old 01-26-2015, 03:03 PM   #5
fonzie's Avatar
Probably it is 7 amps on the 12 volt (approximately) side of charger which would be about 84 watts.
Fonzie
Old 01-26-2015, 07:36 PM   #6
TGR
TGR's Avatar
A few years ago, I ran a notebook PC with a 140 W inverter with complete success. I still use that inverter to charge cell phones and other similar devices but I haven't tried a newer notebook PC on it. Your notebook's power cord likely says 1.7 amps and that would be the charging transformer's maximum power rating. Your notebook will run much less than this ~200 W maximum transformer rating.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is offline   Reply With Quote
electric, electrical
