Old 12-05-2013, 05:16 PM   #1
Another question please
When using the fresh water tank and water pump, does the city water have to be turned off?
2014 Ford F250 Lariat
2014 Rockwood Signature Ultra Lite 8280 WS
Louisiana before, fulltiming since April 11, 2014
blog--- www.gozatravels.blogspot.com
Darrell is offline   Reply With Quote
Old 12-05-2013, 05:21 PM   #2
Batts-toy's Avatar
If you run the pump and pull from the tank with the city water on you will get a mix of the two sources. If you want only the water from the tank the city water has to be turned off. I do this sometimes when DW takes a shower and I have soft water in my fresh water tank because city water will make her itch.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 12-05-2013, 05:26 PM   #3
Soft water in your tank? Are you treating it?
Old 12-05-2013, 05:41 PM   #4
Batts-toy's Avatar
No, I fill the tank at home which has a water softening system and carry it with me.
Old 12-05-2013, 06:00 PM   #5
Herk7769's Avatar
I believe you will get water from the source with the highest pressure. If the city water pressure drops (enough), the pump should start and try and boost pressure.
"Enough" is the operative word since the "cut in" pressure is pretty low.
While Shurflo does not specifically warn against trying to run the pump with another source of pressure, cycling ("floating") of the check valve protecting the fresh water tank may cause permanent damage.
http://www.shurflo.com/files/RV-Inst...44%20_444_.pdf
HAM CALLSIGN - KC3FFW
Old 12-05-2013, 07:21 PM   #6
Batts-toy's Avatar
I wasn't suggesting running them at the same time, I have had situations where I had them both on at the same time. Individually (one at a time) had low flow but with both on higher flow than either alone (and yes the pump cycled on and off) so I sermised a mixing of the waters was occurring thus my statement. The shower part (which I could have stated better was to show where I shut off city water and turned on the pump for DW to shower with soft water from the tank. Thanks for the info and the link.
