03-31-2017, 12:11 PM
another Water filter replacement question
I have a 2015 2304S Rockwood tow behind with a FR1 filter canister and want to replace my carbon filter (KW1 with a simple (ie cheaper) filter cartridge. We carry/ buy bottled water for drinking and cooking so only need to filter out sediment from city water. I have been on- line and there seems to be some question about the FR1 cannister being discontinued and therefore questions about proper cartridge replacement. Has anyone actually replaced their cartridge with a simpler sediment cartridge in the FR1 cannister? I would greatly appreciate the information on your filter source.
PaPa Larry
2003 F-250 w/ 7.3 Power Stroke Turbo Deiesel
Still going strong w/ 200,000 miles
03-31-2017, 12:13 PM
If that's the only thing you need it for, I would suggest just buying an external one and hooking it to your water hose.
MiniLite 2506S
Ford F150
03-31-2017, 12:14 PM
Just bypass the other one.
MiniLite 2506S
Ford F150
03-31-2017, 05:07 PM
Thanks for replying. I have considered that and may well take that course if I can't find filter that fits.
03-31-2017, 09:03 PM
Bypass it anyway before it cracks and floods your trailer. Use an external filter. Lots of folks here reporting cracked filters.
1/2" coupling at Home Depot - 67 cents.
2011 Traverse LT, 3.6L, FWD
03-31-2017, 09:10 PM
Thanks, I have some experience with plumbing so it would not be a problem to make the change. I guess I should start looking for an in line filter.
PaPa Larry
03-31-2017, 10:39 PM
Do a search in here and you will see the onboard filters are notorious for leaking...many of us have removed them and gone to an outside filter to avoid any flooding problems inside.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
04-01-2017, 12:19 AM
Thank you, I am convinced. I am going to see what is available for in line sedament filters and what I need to bypass the existing filter.
PaPa Larry
04-01-2017, 02:02 AM
Just as confused as you
Just go to Home Depot or such and get a whole house filter and fittings to connect to your hose. I have a 25 ft and 6 ft hose and sit the filter under the TT out of the sun. The filter cartridges are a lot cheaper. I get a pack of 2 10 micron filters for about $10.
Richard & Jill
04-01-2017, 06:47 AM
I went to Home Depot and bought a whole house filter with bypass and replaced the filter that came with the trailer. I do use the old filter out of the trailer for when I fill the water tank hooked up with a hose.
04-01-2017, 11:00 AM
Thanks LarryS and Scrapper. I am headed to Home Depot this Sunday for the parts to make the change.
PaPa Larry
04-01-2017, 02:18 PM
Left Coast
04-01-2017, 03:55 PM
StlClay
I ingnored the installed filter after winterizing and seeing the price. My canister is now empty. I just use inexpensive in line Camco filters from Wal Mart and change at a minimum of twice a season. Now winterization is easy and easier on my back
2014 MiniLite with
Nissan Frontier
04-01-2017, 05:48 PM
Canadian Member
The FR1 canisters do have a lot of reported problems but the CC1 canister is OK, at least the 2 that we've had have been fine.
OP has the FR1 so it may be wise to remove it.
If you always hook up to a treated "city water" system then those blue bullet style filters will work fine but we camp at some private campgrounds where I don't trust the well water so I buy F1Pb carbon filters for my CC1 canister from the RV Water Filter Store
04-01-2017, 09:34 PM
We have a 2013 Rockwood 2608ws and have changed the filter with ones purchased from Lowes and still use the filter system that was installed by Forest River and have not had any problems with cracks or leaks. just been lucky I guess.
04-01-2017, 10:54 PM
Interesting that FR may be on the third version of the filter housings. Mine came with a Water Pur RCS 10 inch.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
04-02-2017, 10:42 AM
My 2509s has the Water Pur RCS 10 also. http://www.hannarv.com/P/TheWaterPur...estRiver/33482
04-02-2017, 10:49 AM
That same filter in our roo cracked spilling the water into the roo, only the amount that was in the filter since the system was shut down. When trying to replace I realized they had discontinued that canister model and had to be replaced with a whole new canister, mount, and filters
We opted to simply remove the whole filter system, since we bring our own bottled filtered water with us for drinking, and we always use an external filter before filling up the roo or using city water anyway.
04-02-2017, 03:54 PM
If you leave the filter installed in the TT when you winterize it will fill up with antifreeze. Then when you flush it out the pink stuff will stay in the lower part of the canister for quite a long time. My suggestion is to remove it.
Richard & Jill
04-02-2017, 09:43 PM
Thank you Bandit, ABLINDMULE, & sCRAPPER. This forum has been a great souce of information. I am convinced getting the water filter out of the trailer is a smart thing to do. I picked up the fittings for the bypass at Home Depot, but have not decided on an external filter yet. We are happy with bringing/ buying our drinking and cooking water so are going to choose a sediment filter for outside the trailer. This all started when our charcoal filter was left outside overnight and a bear chewed it up! We then traveled for a while with no filter which resulted in sediment clogging all of our faucets. Again, thank you everyone for your imput.
PaPa Larry
