Old 06-28-2013, 09:05 PM   #11
Ooops....should have told you that I sewed a "hem" that is used at the top for a curtain rod and have them between the curtains and window.
NanaKaren
Karen Elling
2012 Rockwood Mini Lite 2109S
Useta have a 17 ft Casita LD twin bed mod &
Coleman pop up
NanaKaren is offline   Reply With Quote
Old 06-29-2013, 11:08 AM   #12
Rev Roy's Avatar
Thanks for all the tips, folks...but trying to cool the TT so late on a 110 degree day proved to be a fool's errand.
When I arrived at the ranch about 5:30pm the TT was a stifling 114 degrees. I opened the vents, got the box fan going, turned the a/c on set at 72, then took a cold adult beverage with me as I sat under the shade trees and waited. After 30 minutes I went in to see what progress the a/c had made. A/c was no longer on. After a valiant try, it gave up and threw the circuit breaker...leaving the TT at 112 degrees.
I can take a hint. This baby wasn't going to cool down anytime soon, so the dog & I jumped back into the truck and headed home. Moral of the story: On days when the temp nears or exceeds 100 unless I get out there early and get the a/c running BEFORE it falls behind I may as well stay home.
I went back early the next morning, fired up the a/c and managed to keep it relative cool all day even with the outside temp hovering around 100. And for my effort, as usual I was rewarded with some magnificent sunsets and sunrises.
2007 Rockwood Signature Ultra Lite
Rev Roy is offline   Reply With Quote
