Old 06-26-2013, 04:45 PM   #1
Rev Roy's Avatar
Any tips on keeping TT cool?
It's going to be crazy hot at the ranch tomorrow...somewhere around 107. By the time I get there at about 5:30pm the TT will have been baking in the sun all day, so cooling it down will be a challenge.
I know the first tip is to park it in the shade, but that's not an option on this tree-sparse property.
Other suggestions?
2007 Rockwood Signature Ultra Lite
Rev Roy is offline   Reply With Quote
Old 06-26-2013, 04:48 PM   #2
tomjsas's Avatar
Don't know that I can offer much of any suggestion there. Reflective window treatments can help some, but as you say, the whole unit is just going to be hot period given the fact that it has been sitting in the sun all day. In getting ready for this weekend with temps near 100 here in Colorado, I turned the A/C to just above 80 and started the fridge. At least that way, the furnishings and the like won't be scorching hot when I get to the campground hopefully and it will cool down a litte more quickly.
Pull-Rite 16K Super 5th
2014 Rockwood Signature Ultra-Lite 8289WS
2011 Chevy 2500HD - DuraMax (Just over 5000 miles now!)
Nights camped in 2014 - 21
tomjsas is offline   Reply With Quote
Old 06-26-2013, 08:10 PM   #3
dkb74's Avatar
Helps to cool it faster by opening the vents when you first turn on the AC. Other than that, I've got nothin'. Sorry!
~ Darlene ~
2014 Coachmen Mirada 35BH
previous owner of
2014 Rockwood Mini-Lite 2306
dkb74 is offline   Reply With Quote
Old 06-26-2013, 08:23 PM   #4
Just Love to Camp
TheFordes's Avatar
Put your awnings out to keep the sun off the camper. Of course keep the doors and blinds shut as much as possible. or be like us and rock 3 ACs.... Mama doesn't like to be hot!!! Good luck and stay cool. Plenty of fluids
Camped 54 Night 2012
XLR Thunderbolt 386*12
"Bertha The LeadSled" is her name
2012 F450
TheFordes is offline   Reply With Quote
Old 06-26-2013, 08:40 PM   #5
MI Camperz
bodzcampers's Avatar
Extra fans for breeze and to circulate the A/C? Breeze at least gives you the perception of coolness. I also like the suggestion of vents open to help pull out hot air (rises) while the cool air is replacing it.
MI Camperz
bodzcampers is offline   Reply With Quote
Old 06-26-2013, 08:57 PM   #6
Weezer's Avatar
Is shore water an option? If so, use a trick I have given folks back when ex and I owned an AC business; Put a hose on the roof of those soaker hoses...since the area you're trying to cool is much smaller.
There's an auto parts store here in town that actually uses a sprinkler system on their roof and reclaims/recycles the water.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 06-26-2013, 09:31 PM   #7
dcheatwood's Avatar
If you have running water, hose down the top and sunny side for 20-30 minutes while a/c is running. The cool water will help cool the top and sides so a/c can work faster.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
dcheatwood is online now   Reply With Quote
Old 06-26-2013, 09:37 PM   #8
2012 Micro Lite 21 FBRS
Guapotims's Avatar
When you get there, turn the A/C on and then go for a ride. Kill time at a walmart or somewhere cool, have an Ice Cream cone, then go to the trailer and take a "cold" shower, leave your hair wet (or damp). You can even get under the spray nozzle on the end of your water hose, A few quick squirts in the air should cool you down. Then go inside, You'll be much cooler while your trailer cools down.
2012 Flagstaff Micro Lite 21 FBRS
Guapotims is offline   Reply With Quote
Old 06-27-2013, 01:03 PM   #9
Playtime III
Playtime III's Avatar
Go to a box store and pick up a roll of this: Shop Reflectix 25-ft x 24-in Reflective Insulation at
Cut to the size of your window(s) and insert them between the glass and the blinds/drapes. Don't forget to put some between the dome and flat plastic in the bath skylight (close to the dome as possible). We were able to get the inside temp down to 75 degrees (65 at night) when it was 102/90% humidity with only 1 (13.5) AC and we had 33' of trailer to cool. The only drawback is you have to use your interior lights as the RV will be very dark.
Playtime III
TT 2011 2902SS
TV 2007 F-150 SC 4x4 5.4
800 wd/dual cam sc
Playtime III is offline   Reply With Quote
Old 06-28-2013, 09:04 PM   #10
Reflectix does help cut the inside temp down, but, in another RV we had, it also collected condensation between it and the window. You might try the solar screening that is used in homes (makes the windows on the outside look black). This is rated for different percentages - I've used both 70% and 90%. For our TT, I use the 90% . It's lightweight, works well and allows air through so no condensation.
Hope you find a happy solution!
Karen Elling
2012 Rockwood Mini Lite 2109S
Useta have a 17 ft Casita LD twin bed mod &
Coleman pop up
NanaKaren is offline   Reply With Quote
