Old 10-27-2011, 12:23 PM   #11
Murph Bed Issue
Originally Posted by rschoono289 View Post
Celicabob
We purchased a ETC 181 this summer and have just completed a 4751km trip to PEI and thru Maine,New Hampshire, Vermont,Quebec and back to Ontario. We have no leaks and the ETC 181 is easy pull using 2002 Tundra 4.7 V8. Need to warn you of a safety issue unique to the 181 Murphy bed. My wife got trapped in the bed as it can close quickly if someone is near the hinge point. It auto rotated into storage mode in seconds. They have a small knob which is suppose to hold a latch connected to bottom of murphy bed but this can come loose. No other safety to avoid the bed from closing with some one on the bed. I notified FR engineering as this must be fixed. Tie a rope around the latch and secure to the knob as backup.
I havent tried the oven but everything works fine. (the smoke detector is a bit sensitive and can be set off using a toaster). Enjoy your new ETC 181
Hi Roy,
FR must have heard your concerns. Ours (2011 Model) has a safety strap that latches like the mattress tie downs & is mounted to the bed & the H2O pump side of the dinette.
Took ours on the first trip last weekend for a shake down, only about 85 miles away. All went well until I found a tree with the awningÖ
Now itís going in for repairs, so we can have another trip in Nov.
All the best!
Thanks, Bob
2011 Tahoe w HD Tow Package & WDH
2017 Rockwood 2109S
Celicabob is offline   Reply With Quote
Old 11-01-2011, 08:06 AM   #12
Murphy bed
Celicabob
Good to know the safety strap is improved for 2011. FR has really been good they took the trailer back to factory from Canada to make the safety upgrade. Impressed!
Have you ever put your ETC 181 on CAT scales?
My last CAT reading
ETC UVW (yellow sticker) 2668
CAT TT axle 2880
ETC weight 3337
calculated hitch weight 457 (using E2 WDH + bars = 75 lbs)
13.7% of ETC weight, can still feel pull/push when traffic passing on left
Roy & Jean
2010 Rockwood mini Lite ETC 181
2002 Toyota Tundra 4.7l 4x4
Prodigy P3, E2 WDH
rschoono289 is offline   Reply With Quote
Old 11-01-2011, 11:56 AM   #13
On Scales
Celicabob
My last CAT reading
CAT TT axle 2880
ETC weight 3337
Hi Roy,
No I have not put it on scales, just hooked it up and went. Thanks for the info!
Only time a felt anything from the trailer was going over a dip in the road too fast and it oscillated the back up & down a couple of times.
Otherwise I donít even know itís thereÖ
Thanks, Bob
2017 Rockwood 2109S
Old 01-09-2012, 12:23 PM   #14
ETC 181 Cover
Hello All,
Since the one's of us on this thread are 181 owners, I wanted to get any input as to a good cover for the trailer, (brand, model, etc.).
I purchased an AC cover & my GF bought wheel covers but I would like to cover the entire unit to keep the sun & UV off the roof.
Any help or ideas would be appreciated!
Hope everyone had a Happy New Year,
Thanks, Bob
2017 Rockwood 2109S
Old 01-09-2012, 03:16 PM   #15
ETC 181 Cover
Celicabob
Sorry I cant contribute on which cover to buy. I also bought cover for the A/C and for the wheels. Also looked for solution to reduce humidity while in storage at farm. Found a unit that absorbs moisture into crystals. You need to plug the unit into 120v outlet to allow the moisture to evaporate. I havent been back to trailer since early Nov so not sure how effective this unit works. Also heard that blocking refridg vent on roof eliminates moisture in refridg (not done). Used dryer sheets to stop mice (perhaps wishful thinking) Also put the trailer on 4 ft 2x8 weather treated lumber. My ETC 181 had Murphy fixed at factory so bed is now double strapped and has latches both sides which secure the bed in storage mode or when down. The Murphy bed hinged right and left and top side wood are replaced. Also sides of dinette seats changed so bed now is parallel to floor. Overal pleased how FR took responsibility for defective bed. Looking forward to camping in 2012.
Roy & Jean
Prodigy P3, E2 WDH
Old 03-28-2016, 05:45 PM   #16
HikerBob
Still Own It?
Originally Posted by greti View Post
Any Rockwood Mini Lite ETC owners out there? I am waiting for the ETC 185 model but I have seen very little information written from an owner on this unit!
Do you still own your MiniLite ETC?
HikerBob is offline   Reply With Quote
Old 04-03-2016, 10:18 PM   #17
Ambassador
Ken K.'s Avatar
Well I don't have an ETC 185, I got the larger Mini Lite, the 2502KS. It runs 6500lbs dry. We love it. the Rockwoods are solidly built, and generally pull very well when set up properly. The only issue I have had in 18 months of heavy use is the radio would not work exactly as it should have. We had it replaced under warranty. I did upgrade my analog Coleman-Mach thermometer to a digital for $55, this was an excellent decision. It stays with in a tighter temperature range now. In general one of the most serous issues I have seen discussed on the forums about the Rockwoods has been bare laminate wall boards in the wheel wells. I have seen enough of the pictures from different people to know that it's been an issue for the manufacturer. Get a thorough walk through and make sure everything works before you leave. One other thing you will want is a Tekonsha P3 Brake Controller. It's a proportional control brake controller.. The harder you press the pedal the harder the trailer brakes apply. You might also consider a beefy equalizer hitch for sway control. Hope this helps
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
Ken K. is offline   Reply With Quote
Old 04-03-2016, 11:15 PM   #18
I hope that's a typo. My Mini Lite 2503S weighs 4448 dry. GVWR is 6539.
Name:	Mini Lite VIN sticker.jpg
2011 Traverse LT, 3.6L, FWD
Old 04-03-2016, 11:44 PM   #19
HikerBob
The Dry Weight shown on the yellow sticker in our 2011 MiniLite ETC 181 reads 2729 lbs. I've not put in on a scale, but it handles quite nicely behind our 2002 Lexus RX300 SUV. The main thing we were looking for when we bought it was to have something the two of us could camp in comfortably, have a full bath, and be light enough that we wouldn't have to buy a truck to haul it around. We live near the Sierra Nevada and have taken it over 10,000 passes and on rather less than wonderful roads a few times without issues. I use a sway bar in Nevada winds, as they can get pretty strong at times. The only thing we have found to be an issue is the collapsible wobbly table legs, but I think I saw something on the forum that might help - windshield latches to hold it onto a board mounted across the face of upright Murphy Bed. Of all the truly light weight trailers (under 3,000 lbs dry) that we've seen, none can match this one.
