Old 09-10-2015, 09:00 PM   #51
Oldtool2; maybe this will help you. I replaced my Coleman Mach with a Honeywell. The Honeywell only did one fan speed, so I had to wire the two fan wires to a single pole single throw switch to let me switch speeds. You shouldn't have to do that, since you've got a terminal for each speed.
2011 Traverse LT, 3.6L, FWD
Old 09-11-2015, 11:13 AM   #52
On the Honeywell only have one fan speed and would have to add a switch if I wanted both speeds. Sense I don't need the slow speed will not add one. If I had a heating stip I might need slow but don't.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 09-12-2015, 09:37 AM   #53
Originally Posted by gljurczyk View Post
If you touch the yellow and red together the compressor should start. If you have a switch that say's electric or gas make sure it is on gas. Take a picture of the sub base so I can see how they marked the screws on the honeywell I can not find a diagram for it. Then I could probably tell you exactly...
Here is a photo that shows how Honeywell marks their connections.
Jim
George Bernard Shaw
Old 09-12-2015, 09:50 AM   #54
I have a Rockwood 2703ws with three slides. I paid extra for the 15K and slide awnings based on what I have read on the forum. I have found that insulated covers on windows and the two skylights can help. Once it cools down at night I set it at 70 during the day and have had few issues. We live in Florida and camp in September through May.
Rockwoodjoe is offline   Reply With Quote
Old 09-12-2015, 10:12 AM   #55
Witch Doctor's Avatar
Jim
okay then hook-up just like that and the way I said in an earlier post. taping 3 wires off, it is battery operated correct they use that to hold the program when the power go's out but you will need them to make that stat work. .....
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-12-2015, 10:17 AM   #56
Covers on the vents are a good idea to help keep the unit from heating up so much. Insulated windows would have to be ordered when the trailer was being built. I guess you could add plastic but it would need to be added on the inside or it might blow off when traveling down the highway.
Jim
George Bernard Shaw
Old 09-12-2015, 12:29 PM   #57
Left Coast
Jim
At Lowes, and maybe HD, you can get a roll of reflective material, like what's used in cars behind windshields, cut it with scissors to size, and place it between window and shade...shade will hold it in place...really works good
Old 09-13-2015, 08:38 AM   #58
I like the idea of what you're talking about. What I had always seen was at auto parts stores and you had to peel one side of it off to stick it on the window. This sounds like it's just held in place and could be removed easily if you wanted to. Am I right?
Jim
George Bernard Shaw
Old 09-13-2015, 08:52 AM   #59
Left Coast
Jim
Yes....When I bought a roll ( it's not expensive) they only had one width....when I went to Nashville, I cut some and placed into position...what a difference ..I.duck taped 2 pieces together for a larger window and the shade held it in place....left in while traveling, the trailer stayed alot cooler and didn't take near the time for the a/c to cool it down.....at the store I use, I found it in where the house insulation is.
Old 09-13-2015, 08:59 AM   #60
Who Dares, Wins
doc73's Avatar
It is called Reflextics and is what I added to all my windows and vents depending on sun location and such. I think it was $25 for the 2ft wide roll that did my entire trailer.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
