Originally Posted by Hman0109
Frenetti, how did you replace your thermostat? Where did you get it from?
Herman:
If you have a Coleman-Mach, see the attached. I used a Honeywell from Home Depot, but the pic should help you with about any model. You do have to add the switch if you want hi/lo fan speed. If that bothers you, you can go with the Digital Coleman-Mach, which will be plug-and-play, but cost you more (and I don't think it's programmable).
2011 Traverse LT, 3.6L, FWD
