Old 11-04-2014, 03:16 PM   #1
Are my stock tires going to be ok
On my truck I have goodyear eagle ls-2 rated for 2400 pounds each my truck is a 2013 chevy silverado 1500 extended cab standard box ltz. My truck is rated to pull 9600 pounds we ordered a Rockwood signature Ultra Lite with diamond package 8280 the weight is 7500 pounds. just wondering do I need to get new tires on my truck or will stock tires be ok thank you
ti cat is offline   Reply With Quote
Old 11-04-2014, 03:22 PM   #2
If they are P rated tires, in a word, NO. You need LT LR D or E tires on your truck.
Old 11-04-2014, 06:38 PM   #3
When I picked my RV (8280) up from the dealer I had the stock tires on my Tundra (load rated 2600 lbs.). I did have the tires aired up to their max of 45psi. 5th wheel towed fine--however, it was about a 70 mi. trip on level to rolling two lane highway. Prior to heading out West through the Rockies I installed LT tires on the Tundra. With the LT (E rated) tires and other suspension mods (Bilsten shocks, sway bar, Air Lift bags) I felt in complete control and the RV followed me like a dream. Just know that your ride comfort will be more harsh with the "E" rated tires when not loaded or towing.
2014 Rockwood 8280WS
2010 Tundra 5.7 Dbl Cab 4x4
ronb707 is offline   Reply With Quote
Old 11-04-2014, 07:00 PM   #4
My tires are p275/55 r20 any recommendations on a good LT tire this size
Old 11-04-2014, 07:14 PM   #5
Everybody has a favorite and mine are the Michelin LTX M/S2. It comes highly rated from a number of sources (do a search) and owners report upwards of 80,000 miles before wearing out. However, they are a little more expensive. But what I like about any Michelin tire is that they don't have issues of pulling or out of round. I am very particular in this regard and it is a time waster and frustrating when tires aren't perfect.
Here is a link to the tire:
http://www.tirerack.com/tires/tires....del=LTX+M%2FS2
Old 11-04-2014, 10:13 PM   #6
Ret E-9 Anchor-clanker
donanddona's Avatar
"P" Passenger rated tire. Used to pull my 5r for the first year (pictures). Not good.
donanddona is offline   Reply With Quote
Old 11-04-2014, 10:15 PM   #7
donanddona's Avatar
Sorry.
Sidewall flexing causes cracking. Almost caused a blow out.
ID:	65868   Click image for larger version
ID:	65869   Click image for larger version
Old 11-04-2014, 10:28 PM   #8
B and B's Avatar
I use LTX A/T2 which tow great also have lots of snow and cut through the slush, noiser than the LTX M/S2 but in my case I like them. I run 65 lbs for my 9,200 lb fiver.
Brian
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 11-04-2014, 10:36 PM   #9
With your tires inflated to the maximum 44 psi you have 4800 pounds of capacity but your truck axles are only rated for 3900 pounds. Your 5er has an emptry hitch weight of almost 1100 pounds. Increase that with what you will probably put in the front of the trailer and the weight of the hitch, full tank of gas, you, wife, kids and other stuff you will put in the truck and you will probably be over the the 1750 pounds of weight carrying capacity of your truck. I have a similar truck pulling a ball hitch trailer and I must be very carefull to not put anything heavy in the truck bed when the trailer is attached in order to remain within the capacity of the truck.
Windjammin is offline   Reply With Quote
Old 11-05-2014, 03:19 AM   #10
ARLO
I put a set of Cooper HT3 10 ply load range E tires on my F150 Ecoboost Crew (18" wheels). They ride nice and tow even nicer, and you won't break the bank. Cost was about $850 and got a $70 rebate. The P rated factory tires are basically mush but ride better than 10 ply tires
rlocicero is offline   Reply With Quote
tire, tires
