Old 03-16-2019, 12:48 PM   #1
Indy500's Avatar
Aren't these numbers about maxed
This is a 8288wsa and it came with a 10k reese revolution hitch. I wonder why they didn't put a 16k hitch on it? The photo of all the specs 2nd pic , is from the brochure. Click image for larger version
ID:	198885Click image for larger version
Indy500 is offline   Reply With Quote
Old 03-16-2019, 01:02 PM   #2
probably since 10,000lbs is the loaded weight....why would you need more?
(add Vehicle Weight, and Cargo Capacity = 10,000)
formerFR is offline   Reply With Quote
Old 03-16-2019, 01:23 PM   #3
Indy500's Avatar
I was thinking safety, why take it to the max? I know what your saying and it's good. Max is max however you look at it . I can only load so much in the 5er anyway To keep it within limits . Maybe I'm just be paranoid, I'm a worry wart about safety .
Old 03-16-2019, 02:01 PM   #4
the ‘max’ is not a breaking point, it’s simply a safety measure
The Turners...
Old 03-16-2019, 02:55 PM   #5
cmac7203's Avatar
Also, some of that weigh is transferred to the TV (10-15% or so)
2019 Rockwood 2707WS
2009 Ram 2500 5.7/3:73
cmac7203 is offline   Reply With Quote
Old 03-16-2019, 02:58 PM   #6
Always Learning
I don’t think that comes into play when you’re talking about the hitch. It needs to carry the total weight of the camper (all 10k, regardless of how much of that 10k is carried by the truck).
Old 03-16-2019, 03:51 PM   #7
Close, yes.
Keep in mind an engineer and a company signed papers saying this is ok.
You have a 700+ pound margin.
Typical of trailer manufacturers. They will go for the minimum.
Typical is #12.000 axles on a #14.000 trailer! Cause part of the weight is on the hitch, about #2,000 pounds.
Since the engineers house is on the line here there is a safety factor included of likely 20% but, that is not a license to overload the fiver. The axles, springs or tires might break.
Time to start worrying about your trucks payload.
tomkatb is offline   Reply With Quote
Old 03-17-2019, 05:41 PM   #8
The hitch weight(unloaded) is 1530# that's the payload you need available on your tow vehicle. The hitch needs to be rated for the trailer weight; but, it does not carry that weight.
dhfenton is offline   Reply With Quote
