Old 08-22-2013, 02:53 PM   #11
djmac1964's Avatar
As they say- there are many ways to skin the ole cat. I leave both tanks open and usually have a good feel for how long one tank lasts. Now that I understand my switchover, I haven been surprised yet.
On edit- I'm not implying that others don't know how to use theirs. I literally didn't understand it and ran out of propane entirely before I got a grasp on mine.
I finally figured out how to use the switch, and read the dots, this year. I do it the same way you do now, and it works fine. Just have to remember to check the valve every couple of weeks.
Don
2013 XLR 27HFS Toy Hauler
2014 Silverado 2500HD Z71 Crew Cab
99 Club Car Golf Cart
djmac1964 is offline   Reply With Quote
Old 08-22-2013, 03:06 PM   #12
Rev Roy's Avatar
This is what mine looks like. So it's a manual switch, right?
2007 Rockwood Signature Ultra Lite
Rev Roy is offline   Reply With Quote
Old 08-22-2013, 03:13 PM   #13
TURBS's Avatar
Yep .... manual.
Turbs
Old 08-22-2013, 03:19 PM   #14
I stand with Post#4 & 6. Youroo!!
Old 08-22-2013, 03:23 PM   #15
Rev Roy's Avatar
Originally Posted by f1100turbo View Post
Yep .... manual.
Turbs
Thanks, folks!
You can't really see it in the pic but there is a green strip in the middle of the black lever. Does it turn red when that tank is empty or in some other way give you a clue on tank levels?
Old 08-22-2013, 03:42 PM   #16
KyDan's Avatar
If you've ever had to get up in the middle of the night in COLD weather
and get dressed and go outside to open the valve on the 2nd tank you
might re-think how you manage your tanks!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 08-22-2013, 03:43 PM   #17
Brother Les's Avatar
That is on a 2007, very strange? I had a 1995 model and it is 'auto'.
Brother Les
Old 08-22-2013, 03:46 PM   #18
I use a very small 'auto' temp space heater to 'cut the chill'..... I will not sleep in my camper at night with the furnace coming on and off at night. Furnace is shut off.
Brother Les
Old 08-22-2013, 04:30 PM   #19
fonzie's Avatar
I think this is still an auto change over regulator: open both propane tanks, if arrow is green as shown in photo, close the tank that the arrow is pointing too. Light up your stove in the trailer and see if green indicator turns red. If it does then turn switch at regulator toward tank that is in service and red indicator should turn green. Then you will know for sure......
Fonzie
Old 08-22-2013, 04:40 PM   #20
Rev Roy's Avatar
Good idea. May try it later, but right now trying to cool the TT down in this 90+ August heat..so in no hurry to crank up stove.
Maybe this is a hint: I now see that the guy I bought this from left both tanks open. That only makes sense it it's an auto, right. Otherwise you would keep the second tank closed until you needed to use it.
