Old 07-27-2013, 10:47 AM   #1
EastlakeRoo's Avatar
Awning Fabric Adjustment
I have a 2014 Wildwood 300bhs and was wondering if its possible to move the fabric over 1 or 2 inches. When it rains we are getting rain inside the door.
ID:	36298   Click image for larger version
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
EastlakeRoo is offline   Reply With Quote
Old 07-27-2013, 11:48 AM   #2
Dave_Monica's Avatar
Yes, you should be able to as long as there's room on the awning tube...doesn't look to be any issue moving it over on the rail end.
Dave
Old 07-27-2013, 11:58 AM   #3
Herk7769's Avatar
Look at how they attached the material to the camper's rail. Mine has a screw at each end. You would have to remove those screws before tugging the material over to the roller end.
You may also need to insert a thin cutting tool into the roller end to cut the plastic rod (and remove it in pieces) to allow the material to slide toward the end. Do not over do it as you will need some space to allow the awning materiel some room to roll up without binding.
Once square and able to roll up without binding; pop rivet the roller end of the awning so it does not shift.
HAM CALLSIGN - KC3FFW
Old 07-27-2013, 04:12 PM   #4
Thanks for the info I'll take a closer look at the screws you mention.
2014 Wildwood 300BH
2011 Ford F350 FX4
Eastlake, OH
