Old 07-18-2015, 01:48 PM   #1
Awning issues.
Me again! We are on our inaugural trip in our mini-lite 2502ks and the awning has stopped working:-( when we push the button to extend the awning nothing happens and the light on the water heater switch goes out. We've checked the fuses and they are fine.
the-s-moores is offline   Reply With Quote
Old 07-18-2015, 03:15 PM   #2
Georgia Frog Rally 2018
aceinspp's Avatar
You got a remote for the awning? If light out maybe it did not ignite. Turn off and try again. Wait a few sec. Later RJd
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 25
aceinspp is online now   Reply With Quote
Old 07-18-2015, 05:35 PM   #3
No remote. The water heater is running fine it's just the light that goes out when you push the button for the awning
Old 07-19-2015, 07:10 AM   #4
mrmichael's Avatar
Need to charge your batteries?
2014 Rockwood 2109S
2013 F-150
Other Motorhome
2013 F-150 Eco-Boost V6
mrmichael is offline   Reply With Quote
Old 07-19-2015, 07:35 AM   #5
Left Coast
If batteries up, pull switch panel and check, with 12 volt test light, the switch for power...If present, check the switch, with test light, when activating switch, to check for power flowing thru switch. If ok, you'll need a ladder to access the plug-in connector at the awning roller...have friend push switch, check for power..if ok, need motor....not to hard to change. Let us know how it goes.
Old 07-19-2015, 07:37 AM   #6
Left Coast
If it ignited, would be easy fix...replace trailer...
Old 07-19-2015, 07:44 AM   #7
Sounds like your battery is dead? Or the motor is locked up and pulling high amps pulling the battery down causing the light to dim.
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 07-19-2015, 06:50 PM   #8
We decided to take a breath and let it be and enjoy the rest of our weekend. We are taking it to the shop next weekend. I'll let you know what I find out. Thank you again. I'm learning a ton!
Old 08-01-2015, 08:29 PM   #9
We finally got the camper to the dealer today. They said motor was stuck and would need replaced. Also replacing our thermostat with is calibrated 9 degrees off. Finally they will be fixing some rust issues on the stairs. This is a brand new camper after one 3 day shakedown trip. Should I be nervous it was this shaky?? LOL
awning
