Old 05-03-2011, 06:34 PM   #1
Awning on a 2604
I was wondering if anybody elses awning on their 2604 have a slight bow in it when it is retracted?
sschifer is offline   Reply With Quote
Old 05-04-2011, 08:46 PM   #2
I have a 8317SS with a slight bow; its called deflection. Its the natural bow of material under its own weight which is exaggerated by its length. If you have wrinkles in your awning when it's rolling up that is what is causing the wrinkles. THe only way to fix it is to increase the diameter of the roller tube, increase its wall thickness or add more webbing internal to the tube to give it more structural rigidity.
Brian, Julia, Matthew (6), Patrick (4)
Ginger (Vizsla #1) & Bandit (Vizsla #2)
2010 Rockwood 8317SS Signature Ultralight
2005 Ford Excursion PSD - MBRP 4" Turbo back - Prodigy P3 - Dual Cam
2Vizslas is offline   Reply With Quote
Old 05-05-2011, 10:17 AM   #3
I figured it was normal. Thanks for the reply.
2604, awning
