06-02-2019, 11:06 AM
Awning Tube LED Lights
Has anyone been able to install LED lights into the channel on your awning , I would like to install an RGB light strip in the channel but I am having a hard time finding one that will fit anyone have any ideas ?
06-02-2019, 11:20 AM
I see all kinds of problems with anything that is permanently installed. Awning tube rotates how many times while extending and retracting? How will you wire it? What will it do to your awning when rolled inside?
Might be able to get a local upholstery shop to make you a strip of material with the cord sewn in so you can slip it into the channel like regular awning material.
On the part that hangs out of the channel add a bunch of grommets and use them to support an LED "Rope" light, running the power supply along the awning support frame until it reaches a power source. I don't see this as practical for Boondocking, more for campgrounds with electric hookup so at this point you can either plug in to outside power plug or one of the extra plugs on the power post..
When ready to de-camp, unplug, pull strip out of channel with LED rope, and store like Christmas Lights (I always used a bucket).
06-02-2019, 11:43 AM
I thought about that I was thinking I could just run the wires up the awning arms and plug and unplug before rolling and unrolling , then the wires would not have to roll up and the light strip would just live in the channel , would be a bit of a pain but I loose so much light behind my slide I that I think the benefit of the extra light would be worth it
06-02-2019, 02:52 PM
Just as confused as you
I have not tried it buy you might a strip with the 3M adhesive tape. Some have a socket on the end to plug the cord into. Run out your awning, put the strip on the awning tube. Unplug the cord when you want to roll in the awning. The LED strips don't get very hot and in a couple of minutes they should be cool enough they won't damage the awning material. Most could be cut to the length you need.
Richard & Jill
06-02-2019, 03:01 PM
2020 Chevrolet 2500 LTZ, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart.
06-02-2019, 03:05 PM
I did not do the awning but I did do the under belly. I tapped in to the light switch to the steps.
06-03-2019, 12:43 PM
Awning LED strip
We have factory installed LED strip in the awning. Don't know how they handle the rotation for the electrical connection, but we like the quality of light it puts out. HOWEVER, after two years about a half dozen LED';s have gone out.. Don't know how I'm going to resolve that if it gets worse.
06-03-2019, 03:29 PM
I'm having the same thing on our Sunseeker awning. Haven't looked very closely at it as of yet, but RGB as well as white LED strips are widely available cheaply, with rainproof (encapsulated in clear silicone-like material) construction. I'm sure I can figure out how to install it after an examination. You can cut these strips to about any length, roughly every 3 inches. they are identified as to where to cut with scissors.
06-03-2019, 04:00 PM
Here's a YouTube video where someone installed them in the roller slot.
They have to be plugged/unplugged each extension/retraction.
They do make roller slot specific lights. They are different than the adhesive type strips that are widely available. Still need removed or unplugged.
I've also seen a track that slides in the slot that holds the ever popular "Rope" lights.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
06-05-2019, 05:29 PM
Our WindSport came with lights like you want. We never use them, because we seldom use the awning. I have thought about putting a strip just under the awning like our Coachman came with. We used them a lot.
Frank
Frank & Brenda
Thor Windsport 27K TST 507 Tire Monitors
2012 Jeep Liberty Limited Jet 4X4, Hopkins TOWD light wiring, Blue Ox baseplate W/Ready Brute Hercules tow bar and Ready brakes
06-07-2019, 08:54 AM
Just an update if anyone following this thread I did buy the following RGB lights from Amazon
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
They slid right into the slot like I hoped they would have ,
I ran the cable through the awning arms alongside the power cable for the awning , for now , I will have to plug and unplug when I extend or retract the awning , I am going to look at options down the road of trying to run the cable with the fabric to avoid this step but for now its whaty I have to work with .
They are wired in a different pattern then the typical RGB lights so when I made up the cable to go from the strip to the control box I had to flip a couple wires to get them to match what the controller was doing , but after that they work good in the daylight , I will post a picture when it is dark out ,
Thanks for all the replies and input .
06-07-2019, 09:06 AM
Originally Posted by robbiels7
Looks good buddy!
2006 F-250 CCSB 4x4 6.0 Powerstroke
Air Lift 5k bags w/ onboard compressor
2022 Keystone Raptor 351
B&W Companion
06-07-2019, 09:19 AM
Kasual Kamper
It says they're battery operated?
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
06-07-2019, 09:21 AM
Originally Posted by Brendon37
Looks good buddy!
Thanks back at you! Cheap and for the most part very easy up grade. I did the same on my golf cart.
06-07-2019, 09:45 AM
Lights of any sort.....Great Bug Attractors....if you love bugs. Blue light seems to be one of the favorite colors. IMHO.
06-07-2019, 09:48 AM
They are powered 12v battery for the trailer power ,
06-07-2019, 09:50 AM
WolfPaq, I agree I am here in Minnesota where the mosquitoes are so big they will carry you away , but I have found with the colored lights they are not as bad as if I was running the clear lights .
06-07-2019, 09:53 AM
My Blue lights under the awning seem to be "WELCOME" sign for anything with wings.
06-09-2019, 10:00 AM
That's why we keep a bug zapper on the other end of the camper.
06-18-2019, 10:33 PM
Our 2016 Surveyor has lights on the awning tube. After a little over a year they quit working and I had to replace the light strip. The awning is a Dometic 9100. The power for lights comes up the back arm.
