Old 07-02-2013, 09:41 PM   #1
Axle Rating
Should I be worried? This is a photo of the sticker on my axle and then a photo of the load rating for TT. GVWR is greater than axle rating... Hmmmm
Rockwood 2604WS. I weighed dry at just over 6000 lbs...
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 07-02-2013, 09:42 PM   #2
jtstromsburg's Avatar
Tongue weight adds to the axle weight to make gvwr.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 07-02-2013, 10:02 PM   #3
Denver, CO
garbonz's Avatar
Yep, you need to weigh the trailer as you use it. You are probably OK. Tongue weight could easily be 800 lbs.
2017 Fuse 23T
Old 07-02-2013, 10:20 PM   #4
The mfg specs show the dry hitch weight to be 739# plus 6,000# axles = GVWR. With a unloaded vehicle weight (dry weight) of 5,676# you have a cargo capacity (propane, water, food, clothes, tools and gear) of 1,025#. Good idea to weigh the camper when you have it fully loaded so you know for sure...we found out we are carrying about 2,000# of stuff....
Sirsea is offline   Reply With Quote
Old 07-02-2013, 11:39 PM   #5
wyo700's Avatar
If you took the dry weight it says and the ccc and add them up you get 7667 if you go by at least 10% of that weight is a tongue then the weight on the axles will only be 6900 lbs so your good if you go by the ideal tongue of 12% then the weight on axles will be 6747lbs which is even better. Does that make sense.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 07-02-2013, 11:45 PM   #6
No, if each axle is rated for 3000# then it would seem to me that the total weight on the axles is 6000#. 6747# would be 747# over their rating?
2016 Siverback 33IK
Old 07-02-2013, 11:49 PM   #7
The others are right that some of the GVWR is carried by the hitch.
But there is no doubt the manufacturer puts the bare minimum on for axles, and probably explains all of the failures we hear about.
Just how much extra would it cost to put the proper axles under our campers?
bakken is offline   Reply With Quote
Old 07-02-2013, 11:53 PM   #8
wyo700's Avatar
Haha thanks dal not the first time you've helped me out. I need to pay more attention. Ya ok that doesn't make sense. My bad dis regard everything I said.
2013 Toyota Tundra
Old 07-03-2013, 12:03 AM   #9
It seems it is more than the bare minimum. How do you balance your weight perfectly between the front and back axle. I mean it seems to me I have to be perfectly weight balanced front to back or I will exceed the max on one axle or the other.
2016 Siverback 33IK
Old 07-03-2013, 12:04 AM   #10
Wyo, thanks for the input. Those brakes giving you anymore problems?
2016 Siverback 33IK
