Old 05-13-2016, 12:08 AM   #1
frozen's Avatar
axle replacement
Hitched to my 2016 Ram 2500 4x4, my Rockwood 8289 was unacceptably high in the front end. I couldn't make any adjustment to the hitch or pin box because there was already inadequate clearance between the truck and trailer. I had two options: trade for a taller trailer or raise the 8289. We chose to remove the stock Dexter 4000 lb. torsion axles which had a 22 degree down angle and replace with new Dexter 5200 lb. with 45 degree down angle. The different angle raised the trailer about 2.3", and mounting hardware added another inch (approx.). The trailer now sits level with the truck, there's 6.25" of clearance between truck and trailer, and the new brake drums are 12" rather than 10". I had to replace the rims since the larger drums have 6 lugs rather than 5, but we stayed with 15" rims so were able use the E rated tires we bought last fall. The project cost a little over $2600, but lots less than trading campers.
frozen is offline   Reply With Quote
Old 05-13-2016, 07:23 AM   #2
Head Rambler
Sounds like a good project. I'd like to see before and after pictures of it.
Gotta go campin!
Old 05-17-2016, 10:53 PM   #3
duramaxlbz's Avatar
What year 8289ws? I have a lifted 2500 and never had a problem.
duramaxlbz is offline   Reply With Quote
Old 05-18-2016, 12:02 AM   #4
I'm also considering replacing a Rockwood torsion axle because of spindle scoring. Did you do the work yourself? I figured I might have to pay about that much to have a shop replace just the one. Thanks in advance for the clarification!
Paul12 is offline   Reply With Quote
Old 05-18-2016, 01:25 AM   #5
Frozen,
Happy to hear your axle swap worked out well.
The swap I did on our Rockwood 8315SS from 3500 pound axles to 5200 pound axles was the best investment I could have made.
Well over 20000 towing miles with no problems, tires are wearing evenly.
John U
2007 Rockwood 8315SS
2014 Silverado 2500HD 6.0L
midnightpumpkin is offline   Reply With Quote
Old 05-18-2016, 04:23 AM   #6
Witch Doctor's Avatar
Originally Posted by midnightpumpkin View Post
Frozen,
John U
Are you saying your tires weren't wearing evenly with the 3500 lb axles?...
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 05-18-2016, 05:18 AM   #7
B and B's Avatar
I raised my 8289 for at the Goshen Rally. Dexter makes a lift kit. Cost is $250. Raises axles 2.5 inches. At Goshen it was part of service being performed. A fellow Flagstaff had it installed at his dealer for $400 in the midwest.
I am happy and had clearance of 6 inches with the F 150 and close to 8 inches with the F 250.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 05-18-2016, 05:38 AM   #8
duramaxlbz's Avatar
B And B. Did not l know Dexter made a lift kit. Where did you purchase it. I need my lifted to clear my driveway approach. Do u have any pics of it lifted?
Old 05-18-2016, 06:30 AM   #9
AquaMan's Avatar
They can be purchased at eTrailer. This kit raises trailer by about 3"
Torflex Lift Kit - Tandem Axle - 2-7/8" Lift Dexter Accessories and Parts K71-724-02
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 05-18-2016, 08:23 AM   #10
frozen's Avatar
Three of the spindles on my 4000 lb. stock axles were bent when I took delivery of the trailer so those tires were ruined in 6,000 miles. Spindles on my new 5200 lb. axles should handle bad potholes or the occasional curb a little better.
axle, replacement
