Old 05-07-2011, 05:19 PM   #1
redhotcrew2004's Avatar
Bathroom fan...
Hi all,
When all else fails, go to the forum members for help!
I have 2910 rockwood 8316ss with a create-a-breeze bathroom fan. We returned home from our last trip to find the fan was no longer working. I replaced the fuse in the fan and checked the breaker box and still no luck. Does anyone else have any other suggestions before I take it back in for service?
Thanks in advance for your help!
Kelly
redhotcrew2004 is offline   Reply With Quote
Old 05-07-2011, 05:28 PM   #2
NorminN.B.'s Avatar
does the vent have to be open?
NorminN.B. is offline   Reply With Quote
Old 05-07-2011, 05:33 PM   #3
I have it open...
Old 05-07-2011, 06:28 PM   #4
fivecodys's Avatar
Make sure the speed selector hasn't been moved to a position between numbers.
This is a long shot but I have seen this happen before.
Bill
2009 Flagstaff 8528 RKSS
2007 Toyota Tundra DC 5.7L V8
Pullrite Superglide 14K
Air Lift 5000
Prodigy Brake Controller
"I've got a mind like a steele.. a......a steele......um.....uh...... what's that thing called again?
fivecodys is offline   Reply With Quote
Old 05-07-2011, 07:09 PM   #5
caper's Avatar
Our TT has a wall switch for the light. The same switch will turn off the power to the fan. Could this be the problem with your unit?
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 05-07-2011, 07:29 PM   #6
I have checked all the knobs and switches and know that's not the problem. I think it is either a loose wire or the motor has burned out. I can't think what else it might be.
Old 05-07-2011, 07:45 PM   #7
frankm's Avatar
Long shot but check that the vent switch is not stuck in the depressed (off) position.
Frank & Rita M
2016 Ford F-150 XLT Ecoboost
2017 Rockwood 2703WS
frankm is offline   Reply With Quote
Old 05-08-2011, 02:43 AM   #8
showtime0022's Avatar
Sounds like you may need a new fan. During pdi my was replaced.
showtime0022 is offline   Reply With Quote
Old 05-08-2011, 05:33 AM   #9
miatared's Avatar
Looks like you need to a fan. If it's under warranty should be easy.
By the way:
- Fan-tastic fan: high speed fan in bathroom
- Create-a-breeze fan: light/fan combo that hangs in the bunk/sleep area
Good luck
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
miatared is offline   Reply With Quote
Old 05-08-2011, 10:04 AM   #10
Another long shot - make sure that one or both of the GFI's have not been tripped.
...VTX-AL
VTX Al is offline   Reply With Quote
fan
