Old 02-16-2015, 01:36 PM   #11
Flybob's Avatar
Originally Posted by 2ramblers View Post
Thanks Flybob. Do you happen to know what solar panels I would need?
Depends on where you are camping. My main reason for suggesting Generator vs Solar is the CPAP. If that is mandatory, generator is best solution as you could get 3-4 very cloudy rainy days and get little charge or be on a very shaded site.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-16-2015, 01:38 PM   #12
Thanks for your information Flybob.
2ramblers is offline   Reply With Quote
Old 02-16-2015, 01:47 PM   #13
If you really want to run off the grid use a car type battery charger and run it off your generator and charge it up several times faster at 10, 12 or more amps. Also a couple of 60 watt solar panels or larger will make dry camping almost seamless as they charge your batteries as long as there is daylight while you are sitting or travelling. When I am going to be dry camping for awhile I also set up a 3rd deep cycle battery particularly if its colder and I need to run the furnace overnight, that sucks the juice out of your batteries more than anything.
rthomaslyons
2015 Flagstaff 26FKWS
rthomaslyons is offline   Reply With Quote
Old 02-16-2015, 01:50 PM   #14
Thank you rthomaslyons that is very helpful.
Old 02-16-2015, 02:21 PM   #15
bikendan's Avatar
What sort of set-up would I need if I wanted to run an air conditioner, a CPAP machine, one or two lights and TV?
For all that, forget solar and inverters, you'll need a generator.
if you leave the a/c off your list, then a couple of deep cycle batteries and an inverter would work. You could use solar to recharge the batteries.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 02-16-2015, 02:27 PM   #16
rzrnaz has it right 4 6v batteries and 2000w inverter to run everything including the microwave but not all together (excludes ac and hot water). you must consider installation costs also as correct battery wiring sizing, battery enclosure,transfer switch, fusing and disconnect and likely a sub panel would be needed for this setup
palmetto rogue is offline   Reply With Quote
Old 02-16-2015, 04:36 PM   #17
Boondocking w/Flagstaff 21FBRS
We would like to be able to add some "Boondocking" capability to our Micro-Lite. After reading countless posts I think I have a 3 step plan:
1. Most folks seem to recommend replacing the standard 12v battery with two 6v golf cart batteries, and, upgrading the WFCO converter with a Progressive Dynamics 4600 kit to get a 4 stage battery charger. This should give us 2-3 days with 12v only, NO 120v.
2. Add an Inverter to get minimal 120v (TV and computer) from the battery bank.
3. Add a generator or solar (or both) to get full 120v. No A/C unless we go with a 3000+ watt genny.
Am I on the right track?
Henboy is offline   Reply With Quote
Old 02-16-2015, 05:08 PM   #18
Yup. That'll do.
If you are planning on going with an inverter at some point, I might recommend upgrading to 4 x 6v batteries now. Typically you want to have the batteries in your bank to be of the same type and age.
You might also consider 2 x 2000 watt genny's over a single 3000 watt. For the most part, you really only need a single 2000 watt for day to day use. You can always parallel an additional unit for your A/C. A single 2000 watt like the Honda or Yamaha will be more fuel efficient over a 3000 watt genny. They are easier to carry and give you the added benefit of a backup.
rana is offline   Reply With Quote
Old 02-16-2015, 05:13 PM   #19
What do you know about replacing the Converter with a Inverter/Charger?
Old 02-16-2015, 05:35 PM   #20
That's actually the way I went. I carry a magnum 2000w inverter/charger, but still have my stock converter as a backup I can wire in to if need be. Actually... I also carry a second 600 watt PSW inverter as well that I use strictly for the entertainment center (TV, satellite receiver, DVD, etc). The overhead is lower and not much point running 2000 watts just to watch some TV. Of course, I also prefer "using up" a $200 inverter over my $1800 magnum.
The magnum runs into a subpanel and powers the entire rig with the exception of the A/C and the electric side of my water heater.
If you just want something dedicated to plug into, it's not all that difficult. Tying it into your entire rig is a bit more involved, but gives you the most versatility.
On edit: I forgot to mention that the entertainment center is also on a transfer switch so it will run hot from either of the inverters or shore power.
camping, inverter, battery
