06-12-2014, 08:45 PM
Battery charging
Own a 2502s mini lite with the built in battery cut-off switch. I have only camped in it once with no problems. Getting ready for my second trip tonight I plugged it in and turned on the fridge and looked down at the battery cut-switch and realized it wasn't on. I assume the battery won't charge with this switch off and the camper plugged in?
06-16-2014, 10:07 AM
AKA: 'tiredTeacher
Keerect! The battery charges off the converter and the cut off is between the battery and the electrical panel, isolating the battery. Only the power jack (if equipped) and emergency brake will operate with the switch off. Your battery WILL charge from the tow vehicle with the switch off as that is a separate circuit notconnected to the electrical panel.
Hope this helps,
AW
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
06-16-2014, 10:50 AM
Yes verified at battery terminals. When plugged in,switch off I had 12.58V with switch on I had 13.19V.
06-24-2014, 03:38 PM
Sorry to hijack this, but found this post when looking into my disconnect switch. I can probably do some rooting around and come up with the answers, but just hoping I could avoid that. I have the push pull disconnect switch in my Rockwood Roo. I assume switch IN is battery connected and pull OUT is disconnect, but my converter fan runs with it OUT when plugged into shore power and turns off when IN. I'm assuming the converter fan is running because the converter is on and also charging my TT battery. Also you say the tow vehicle will charge the battery regardless, but if I want to run my fridge on propane underway which way does the switch go? The DSI needs the 12v from the battery to operate, correct? I know there are opinions on whether to run the fridge on propane while underway, but I'm going on a long trip and last time I did this trip the fridge temp was pretty high by the time I got home. Any info would be appreciated. Thanks
2014 Rockwood Roo 19
06-24-2014, 03:58 PM
adellicson, first of all welcome to the forum. yes the battery disconnect switch must be in the 'connected' position to operate the fridge on propane. I am not familiar with the push/pull type, I would select a position and turn on a 12 volt indoor light if it lights power is on if not move the switch and try it again.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
06-25-2014, 07:42 AM
AKA: 'tiredTeacher
Pull it out and run the fridge en route.We do it all the time,
Wright and Penny
Richmond, Va.
06-25-2014, 07:49 AM
I assume switch IN is battery connected and pull OUT is disconnect, ...
Nope, it's the other way around. Out is on, in is off. I find it easier to remember if you think of it like an emergency stop. You slam an e-stop in to kill power to whatever, same with this switch.
Actually, I wouldn't be surprised if the disconnect was just an e-stop, but without the big red knob.
06-25-2014, 10:11 PM
Well maybe your's is wired differently but on mine Out is on and In is off. You can verify this by simply turning on a light. When the light goes off, the battery is disconnected.
06-25-2014, 10:13 PM
Yep, same here.
06-26-2014, 04:28 AM
Out is on and in is off, battery power disconnected.
06-26-2014, 05:46 AM
I made a "push to disconnect" label for mine because I kept forgetting which was which.
2020 GMC Denali 4X4 2500HD Duramax
2018 Work & Play 25WAB
06-27-2014, 09:03 AM
Yes, I know mine is on when it's out because I'm always afraid I'll bump it with my foot and turn it off which will turn the frig off. I delibrately pushed it in without think about the frig and we had a melt down with all the food. Luckily it was the last leg of the trip back to home so we were able to salvage most o the food.
There's also a switch on the panel that says interior. It only controls a couple of lights however. I've found some screwball wiring in this thing and I suspect that wil be my next project.
