Old 04-16-2014, 09:54 AM   #1
CamperFan's Avatar
Battery/Converter Problem?
I put a brand new 12V battery in our Rockwood 8265S 5th wheel before we went camping last weekend, but I had no lights on 12V power. It didn't even have any power to light the fridge on propane. Charged the battery on a portable charger & put it in the trailer, but still no power. However when I hook the trailers tail light pig tail into the truck, the fridge came on on propane & I have power to the lights. Also, with shore power plugged in, and the battery out of the trailer, the passenger side slide motor won't work, but with the battery in the trailer and shore power plugged in, the passenger side slide motor works. Very confusing. I hooked the new battery to my boat's trolling motor, and it spun the prop real good. Does this sound like my converter is bad?
2008 Rockwood 8265S
2006 Chevy 1500 Ext. Cab LT w/5.3V8 & Tow Pkg.
CamperFan is offline   Reply With Quote
Old 04-16-2014, 09:56 AM   #2
CamperFan's Avatar
Also the manual that came with the camper says my converter is a Parallax 7100 series. Does anyone know what model 7100 series my camper might have, 7155 possibly?
2008 Rockwood 8265S
Old 04-16-2014, 10:12 AM   #3
KMP44's Avatar
Doesn't sound like the battery is bad if the trolling motor runs - a meter would confirm that. If you have a charge on the battery, I doubt the converter is the problem.
Sounds like a fuse in-line between the battery and the load. Usually these are a resettable breaker, sometimes a fuse. Trace your positive wire from the battery back to find it. Also double check your "reverse polarity" fuses in your converter. These can blow if the battery gets connected with the wires reversed.
2022 Columbus 379MBC (Previous 2013 Rockwood Roo 23 IKSS)
2023 F-350 (Previous 2017 F250, 2005 F-150)
KMP44 is offline   Reply With Quote
Old 04-16-2014, 10:50 AM   #4
CamperFan's Avatar
Thanks KMP44. I checked the battery hot line fuse (located about 30" from battery. It was good. The only fuses on my breaker panel are two 30A fuses that set side by side and below them the five or six fuses for the various circuits for appliances such as A/C, water heater, etc. Where are these converter reverse polarity fuses? I am going to check and see if I have power on the hot battery cable where it connects to the breaker panel lug with a simple light up tester this evening when I get home from work. If the tester doesn't show power there, I'll know the break in power is between the panel & the battery.
2008 Rockwood 8265S
Old 04-16-2014, 12:48 PM   #5
fonzie's Avatar
Have a look for a mini-breaker in-line with your positive lead from battery to converter. On a travel trailer it is usually underneath the frame near the tongue. I don't know about a fifth wheel. It needs to be reset, small black button on the side. Hope that what it is.
Fonzie
Old 04-16-2014, 01:02 PM   #6
KMP44's Avatar
Originally Posted by CamperFan View Post
Where are these converter reverse polarity fuses? .
They would be the auto type fuses in your panel. Picture in Post #2 shows the fuses for a WFCO converter.
http://www.forestriverforums.com/for...sed-54683.html
Old 04-16-2014, 01:03 PM   #7
Witch Doctor's Avatar
It is probably 55 amp converter. 7100 series and 55 amp. #7155
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-16-2014, 08:20 PM   #8
CamperFan's Avatar
Thanks Fonzie that was it. The button was on the bottom of the box where I couldn't see it. I thought it was just a junction box, but should have knew better since my boat's trolling motor battery connection has one of these on it and when I had to troll all the way to the landing one day when my big motor's starter went out, twice the lead got hot and tripped this breaker.
2008 Rockwood 8265S
Old 04-16-2014, 09:42 PM   #9
I changed that to an auto reset, I had to stand on my head to find that button one time......
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-10-2014, 01:11 PM   #10
Tina
hmm so do you just press the button? What happens if you say press it twice. Mine is giving me the same problem???
tbeefitz is offline   Reply With Quote
Old 05-10-2014, 02:39 PM   #11
What unit do you own that's giving you the problem? Also what do you mean you pressed it twice? Are you talking about that little black button? Mine use to trip everytime I brought my landing legs up to far it will trip everytime. It would be helpful if you add your unit model and your tow veh. in your line signature..
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-10-2014, 03:06 PM   #12
Tina
I have a wildwood 26tbss. I pressed it twice because it is under the trailer and quite difficult to get at, so I wasn't sure if I pressed it the first time so I did again.Good idea, im a newbie
Old 05-10-2014, 06:06 PM   #13
You should think about changing it out to an auto reset. More then likely it would be a 40 amp. I would call your dealer and ask what the amperage is then you won't have to crawl under your trailer. Do you have any idea why it trip to begin with? Sometimes they are just weak right out of the box. Also welcome to the Forum, and safe travels to you. My first trailer was a Wildwood LE 19', before that it was always tents for us......
Coachmen M/H
Concord
2018 / 300 DSC
battery, converter
