Old 01-11-2017, 03:08 PM   #11
Originally Posted by larryandamy View Post
i agree that you should have the battery disconnect switch on when plugged in at home for the reasons stated.
On the question of two 6vdc batteries in series vs 12vdc batteries in parallel, i have posted on this before in length.
But the short of it is that two 6 volt batteries vs 12vdc batteries is a wash except two 6 volt batteries will last longer (life time) due to larger plate size.. Life of 6 years versus 4 to 5 years.
Two 6vdc batteries require an extra cable and if a cell goes bad on two 6vdc in parallel, then you have zero voltage output vs two 12vdc batteries in parallel where one of the 12vdc batteries would still provide 12vdc but at 1/2 capacity.
Excellent summation!
Thanks.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
Nights Camped: '15 = 22'16 = 46
Old 01-11-2017, 03:19 PM   #12
MNtraveler's Avatar
I would suggest you find out what power converter you have and read up o how it works. Since you have a new unit, you most likely have a converter that will automatically change modes and switch to trickle charge once the batteries are fully charged - meaning they can be left in charge mode indefinitely. But you should check your manual to be sure since this is something you definitely need to know and understand. Once you have read it, you will be able to know what mode it is in by taking a quick voltmeter read with the power converter on (shore power or generator on). Different voltage levels reflect different charging modes.
Hopefully you have a Progressive Dynamics unit.
FAQs About Power Converters/Chargers
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 01-12-2017, 04:53 AM   #13
DouglasReid's Avatar
Originally Posted by DanoHB View Post
So I just got my new TT. I have the battery disconnect on it. When plugged in at home, and not using it, should I have the battery connected or disconnected? I know to connect about a week before we go anywhere, but if I leave connected, will it damage it? I live in SoCal so no harsh winter here or freezing at all. Will just rarely go in trailer at home to clean and stock, but will have power with plugged in.
Simple, if the camper is plugged in to shore power, leave battery disconnect in on position
If no shore power, disconnect battery to keep converter from draining battery!
Maurice, LA
2012 Wildcat Sterling 32RL
2008 Chevy Silverado 2500HD LT Diesel
TST TPMS system w/ Flow-thru sensors
2001 Cougar 281 EFS (sold)
DouglasReid is offline   Reply With Quote
Old 01-12-2017, 09:24 AM   #14
Trailers we've had with 1 12v battery have not lasted very long being plugged in during camping season. In 2008 we bought a trailer had 2 12v battery's installed, they are still in use in their 3rd trailer.
bowebow is offline   Reply With Quote
battery, battery disconnect
