Old 07-18-2014, 12:49 AM   #1
Battery Disconnect Switch
I have a 2014 Rockwood 2910TS Ultralight Trailer that is supposed to have a battery disconnect. Does anyone know where that is?
Also, does anyone know what the switch is above the switch panel that isn't marked. In the switch panel, it of course has all the slide out switches, lights, awning, tank heaters etc.. that are all marked. Above the panel, there is an unmarked switch. I'm pretty sure that IS NOT the battery disconnect. But I was wondering what it actually is. I believe it may have something to do with the antennae amp, but I'm really not sure.
TravelingTexan is offline   Reply With Quote
Old 07-18-2014, 01:23 AM   #2
Terier's Avatar
Hi and welcome to the forums! Sorry that I can't answer your question but I found a variety of answers when I did a quick search from the cabinet in the bathroom, panel above the fridge, to outside by the p-tanks just to list a few locations.
Hopefully someone soon will drop by or that someone that has the same unit will know.
You mentioned that above the panel, there is an unmarked switch. Are you able to post a picture of it? Doing so might yield an answer quicker but no promises.
Old 07-18-2014, 05:09 AM   #3
I also have a 2014 2109S and we are making our maiden voyage this weekend. This is a great place to learn things.
I can finally answer one. The battery disconnect is below Fridge to the right of fuse boxClick image for larger version
Name:	ImageUploadedByForest River Forums1405678093.161893.jpg
ID:	58391. Mine is labeled.
iefman is offline   Reply With Quote
Old 07-18-2014, 05:15 AM   #4
Name:	ImageUploadedByForest River Forums1405678355.231088.jpg
ID:	58392. This is my panel just to right when walking in door mounted to sink cabinet. Lots of blanks fore additional slide out etc. but no unmarked switches.
Old 07-18-2014, 12:15 PM   #5
Terier's Avatar
Thanks lefman for clearing up the mystery. I added a disconnect switch to my unit so I wasn't sure if FR use a pull/push knob too but it looks like they do.
BTW I agree that this is a great site for learning - I know it has made a big difference with my RVing experience.
Old 07-18-2014, 09:19 PM   #6
I did find the battery disconnect. It is in the bathroom, low on the side of the cabnet under the sink. Thanks for the help.
iefman, I've attached a picture of my panel and the mystery switch above it. The panel looks the same (except for the hot switches), but I'm not sure what the one above it is for.
Old 07-19-2014, 12:41 AM   #7
Another mystery is where the light switch is to turn on the amber light that is on the side of the trailer (See picture).
The LED lights under my awning have a switch on the switch panel. I would have thought the switch might be on the actual light like other lights including the one on the front of the trailer. But its not. Any idea where this switch might be (its not the unlabeled switch on my panel).
Old 07-19-2014, 08:10 AM   #8
My amber light is on that same panel and labeled "Porch"
No clue what your mystery switch might be, could it bring power to your whole panel?
Old 07-22-2014, 12:34 AM   #9
Kenv's Avatar
Maybe it is for one of the interior lights? Like a low light in the walkway or just a dual turnon for one on the ceiling.
Kenv is offline   Reply With Quote
Old 07-22-2014, 03:46 AM   #10
Witch Doctor's Avatar
Originally Posted by Kenv View Post
Maybe it is for one of the interior lights? Like a low light in the walkway or just a dual turn on for one on the ceiling.
I do not have your model, but I can tell you that the switch shown is a typical light switch from FR. I have one unmarked switch in my panel to and found it to be the main light high in the ceiling so you have a light lit when you walk in, When I had a 2nd exterior light installed under my second awning, that is the kinda of switch they installed, do you have step light? Also since you said that you can't find the amber switch, check to see if the light bulb is good in it. that could be for that and the bulb is just burnt out. Just a guess. Your antenna amp should be on the plate where your cable is connected It very small button that will lite green when you use the amp for it.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
battery, battery disconnect
