Old 05-24-2012, 06:07 PM   #1
hockey11's Avatar
Battery life
We are camping for the 2nd time in our new tt!!!! This outing will have no electricity, only battery power. We have power awning, power jacks & hitch & water pump. In addition lights will be used & radio. We will be camping for 2 nights. Does anyone know how long a regular battery will last. When using our tent trailer we had battery power for at least 2 weeks, however that was only using lights.
Sharon & Jim, Dutchess
Windjammer 2102w
Ford f150 4x4 EB 2014
2012 30, 2013 25, 2014 29, 2015 37
hockey11 is offline   Reply With Quote
Old 05-24-2012, 06:57 PM   #2
BCRider's Avatar
Its a really tough question to answer in that so much will depend on you and how much power you need to remain comfortable. The on board heater will really suck up power, all the appliances will take up a little each and if you leave lights on....I could go on and on. We just came back from dry camping for 4 days and lost most of our power by day 3. Even though we were being very careful.
Doug and Sharon
2010 Georgetown 300FWS
Jeep Wrangler Toad
VTX 1800 Scooter
BCRider is offline   Reply With Quote
Old 05-24-2012, 07:34 PM   #3
MilCop4523's Avatar
My new battery was 100% charged from last weekend. got home and had to put the slide out once to get under the sink to do some reinforcement for my RVQ support. Pulled the slide back in at teh end of the night and did a battery check.
3/4 power remaining. 2 days may eat up the stand alone charge. Get a small solar charger to keep it charging in the sunny hours and use the slide in out sequence with the truck hooked and powering is my suggestion.
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
Old 05-24-2012, 07:48 PM   #4
Herk7769's Avatar
Without a generator or hooking it up to the truck and running the truck for a few hours, if you use the heater at all it might not last the night.
The OEM battery might have only 65 or 70 AH of capacity when fully charged. The furnace draws 11 amps when running so if it runs constant it will kill a fully charged battery in (75AH divided by 11A =) 6.8 hours to dead if you use nothing but the furnace. Running it less often will give you longer life.
Lights add 1 amp per bulb to that number. Most fixtures have 2 bulbs.
I always charge up the batteries before I go to bed (or quiet hours end).
I HATE waking up in the middle of the night freezing my toes off.
HAM CALLSIGN - KC3FFW
Old 05-24-2012, 07:51 PM   #5
Herk7769's Avatar
The "3/4 power" was not using the indicator lights was it?
That light stays on till 50% remaining.
The "Fair" light stays on till the battery is deader than Elvis.
Name:	Battery Display.jpg
ID:	14373   Click image for larger version
Name:	Charge Chart.jpg
Old 05-24-2012, 08:22 PM   #6
hockey11's Avatar
We are hoping we will not need heat!!!! Our main concern is no power to hookup the camper when we leave on Mon. We have no generator, however if we are able to plug into the vehicle to get it power the tongue jack we should be ok.?!
Windjammer 2102w
Old 05-24-2012, 09:01 PM   #7
donjuanss's Avatar
Once you hook up to the TV you will have power from it. If you see that you need to run something that draws alot of power then just hook up to the TV and let it run a little bit to help out. Also someone suggested a solar charger to help during the day and it does help
U.S. Army Retired Desert Shield/Storm Vet
2014 Silverado Crew Cab
2009 28ft Flagstaff V-Lite
1996 Impala SS 1972 Chevelle SS
donjuanss is offline   Reply With Quote
Old 05-24-2012, 09:51 PM   #8
Herk7769's Avatar
This also may help you:
normal appliance amp draws
Old 05-28-2012, 09:39 PM   #9
hockey11's Avatar
Thanks for the help. We just returned from our weekend w/o electricty & had no problems!!! The worry was for nothing. No heat was needed. We ran the radio, water pump, some lights(min) and had plenty to put awning, slide, jacks & power tongue to use when getting ready to leave!!! Fun was had by all!!!
Windjammer 2102w
Old 05-30-2012, 07:35 PM   #10
Paul & Sheri
pwb01's Avatar
Some tips we've used boondocking for years:
Permanately mount two batteries wired in parallel. Charges with charging system.
Use LED's for all commonly used lights. 1/3 the power draw
Pull one bulb from double bulb fixtures which aren't LED's
Use a 3rd or 4th battery for 4 or 5 days or more, wire in parallel. Charge separately.
One or two lights on at a time, no more
Expand slides, awning, etc with Tow Vehicle running and power still hooked up.
Use accumulator tank. Minimizes power surge with pump starts
Two batteries will get us 3 or 4 nights and 4 batteries 5 or 6 nights, with some to spare. We use satellite radio often and a DVD every night and usually have a game night at least once with lights. Additional batteries are much cheaper than Honda's. I was told to match batteries to be hooked together. Don't know for sure but why not.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
pwb01 is offline   Reply With Quote
battery, led pad
