Old 11-20-2015, 07:14 PM   #1
Battery question
I have a new 2016 FW8289WS. For the first week I've been at a campground with 30amp plug in. Battery has been in the pushed in position; which I assumed was the connect position. I didn't raise rear stabilizers before I disconnected the power cord and tried to use battery power to raise rear stabilizers.....they didn't work. I had to plug FW into my truck to raise rear stabilizers. Battery power panel in FW says battery is fully charged. What could be the problem? Am I missing something here?
GoneMars is offline   Reply With Quote
Old 11-20-2015, 07:19 PM   #2
TURBS's Avatar
Follow the positive battery cable to a current limiting circuit breaker.
Might be two.
See if one needs reset.
Old 11-20-2015, 10:56 PM   #3
RangeMaggotBob's Avatar
The battery needs to be in the pulled out position; pushed in it's in the disconnect position. Doesn't seem right, but that's how it is on our trailer. As far as the battery monitor, maybe it's showing full charge because you are hooked up to the truck, and it's getting the full 13.6 V or whatever it is the on-board battery charger puts out when charging. Good luck and let us know!
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2000i generators
RangeMaggotBob is offline   Reply With Quote
Old 11-21-2015, 05:42 AM   #4
fonzie's Avatar
Push to disconnect and pull to connect.....
Name:	push-pull battery disconnect.jpg
Fonzie
Old 11-21-2015, 09:22 PM   #5
Thank you so much for the responses. I did have it backwards. With the knob pulled out the rear stabilizer will retract on battery power. It was opposite to what I would thought.
Old 11-22-2015, 11:11 AM   #6
Klbrown53's Avatar
I can still never keep it straight. I push it or pull it and then hit the entry light switch on the panel. If the light comes on I have it backwards. Some kind of memory block that keeps me from remembering.
Or, maybe old age.
My wife remembers. But then she is much younger than me. (2 years)
Klbrown53 is offline   Reply With Quote
Old 11-22-2015, 01:32 PM   #7
fonzie's Avatar
Or, maybe old age.
I you remember the old cars, they had push/pull light switches......pull lights on, push lights off....
Fonzie
Old 11-22-2015, 01:32 PM   #8
Or, maybe old age.
You need to label it, like fonzie did.
2011 Traverse LT, 3.6L, FWD
Old 11-22-2015, 08:51 PM   #9
Good way to remember! Push lights off.....pull lights on. I think I can remember that one.
Old 11-22-2015, 09:01 PM   #10
WFD
Just label it and be done with it, that way when you take it out of winter storage in spring time you wont have a memory fart.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
battery
