Old 10-29-2015, 08:16 PM   #1
Bedroom tv
Can anyone tell me how to hook up the bedroom tv using the antenna? I hook up the coax to the outlet but the tv won't find channels. The main tv weighs great on the antenna.
We have a Windjammer 3008w
dkkirkland is offline   Reply With Quote
Old 10-29-2015, 09:19 PM   #2
TURBS's Avatar
Do you have the booster button on at the main tv in the living room?
Old 10-29-2015, 09:21 PM   #3
TURBS's Avatar
This
Old 10-29-2015, 09:38 PM   #4
There's a button on the front and it is on. If you turn it off the main tv goes off. The two inputs below the main tv say "tv" and "antenna". That's where the button is as well. Then there's a single input that says satellite to bedroom. The main tv is connected directly to coax coming out of the wall.
In the bedroom there are two inputs and one is marked satellite receiver. We tried hooking coax to dune of the inputs in the living room but with no luck.
I can take a photo tomorrow if that helps.
Old 10-29-2015, 09:40 PM   #5
Also I have a Rockwood windjammer 3008w
Old 10-29-2015, 09:40 PM   #6
TURBS's Avatar
It would help.
You only have 2 coax connections in your bedroom?
One cable and one satellite?
Old 10-29-2015, 09:50 PM   #7
How do you upload a photo and yes they are two inputs in the bedroom as you asked
Old 10-29-2015, 10:13 PM   #8
Bedroom
Living room
Old 10-30-2015, 08:53 AM   #9
The booster should be on for both tvs. If wired correctly it shouldn't matter if the other tv is on or off. Some tv tuners are more sensitive than others so if your signal is weak that might be issue too. If you have cable and sat connections in bedroom the manufacturer may have crossed these two so try the sat connection. Can be easily corrected by removing the wall plate and switching if that is the case.
2015 Ford F150 Platinum 3.5L Ecoboost
2015 Rockwood Ultralite 2604WS
No longer mine: 2006 Rockwood Roo 23SS
mjbenedict is offline   Reply With Quote
Old 10-30-2015, 09:25 AM   #10
Have you tried hooking up the TV from the bedroom in the main room? That would eliminate the TV itself being the problem.
Also try hooking up the main TV in the bedroom to see if it has the same problem.
Iwritecode is offline   Reply With Quote
bed, roo
