Originally Posted by elchilero53
Never had the problem you describe. Is there a problem with the hitch assembly itself?
No problem.
I was parked on a decline. Even though the trailer was choked and theTV had park brake engaged, there is always some built in torque in the coupler that is relived when you unhook. Once you reconnected, even without moving, things are no longer perfectly aligned which likely caused a slight misalignment and a new set out interferences. Once I was again on level road, a simple disconnect, reconnect solved the problem
