Old 03-10-2014, 02:21 PM   #1
Bent stabilizing jack
Well i took the cover off the t.t this weekend and found everything to be fine on the inside but not on the outside. The rear stabilizing jack arm had bent sometime over the winter i guess from the weight of the snow and also the shifting of my driveway from all the ice and snow. I spent the next day removing the unit and trying to straighten it the best i could. Its a Lippert unit and i was wondering if there was a way to replace just the jack leg and not the whole unit. i went to the website but could not find any replacements. if any one has an ideas or had the same issue please let me know on what you did. i would really hate to pay $500 for a new unit.
bobmart5705 is offline   Reply With Quote
Old 03-10-2014, 02:25 PM   #2
Fulltime family RVer
You can't buy the part separate from what folks on the forum have found. But, if you're handy- you can fix it:
Electric Stabilizer Jacks for in front of axles
Old 03-10-2014, 02:36 PM   #3
Take a picture of it, I might be able to fix it for you. I reinforced all 4 of mine.
Old 03-10-2014, 02:43 PM   #4
NELA
Weezer's Avatar
LOL, and he's OFF and running!
Yer a good aig, OC!
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 03-10-2014, 02:44 PM   #5
checca's Avatar
Here is what happened to me and how we fixed it.
How much to fix? I over loaded my stabilizer arm this weekend.
2013 Lacrosse 318bhs
2010 Toyota Tundra Crew max 5.7 flex fuel / Installed airlift ultimate 5000 air bags and smart lift automatic leveling system.
Yamaha EF2000iS 2000 Watt Inverter Generators
Minooka, IL.
checca is offline   Reply With Quote
Old 03-11-2014, 06:51 AM   #6
Herk7769's Avatar
NOT the Lone Ranger...
Lippert's manual says the sell parts; but not so.
They do sell the entire unit on their web site.
Electric Stabilizer Jack|Lippert Components RV Accessories|Lippert Components
They do sell the motor, though.
Name:	Last Shots 038.jpg
ID:	47527   Click image for larger version
Name:	Last Shots 037.jpg
HAM CALLSIGN - KC3FFW
Old 03-17-2014, 11:08 AM   #7
Klbrown53's Avatar
Timely post for me since it also happened to us 2 days ago. We were set up and asleep in the middle of the night when one of our front jacks buckled. I thought someone had hit our trailer. I suspect that since the RV spot was not paved that the ground settled and allowed extra downward pressure on that jack but do not really know. We took it by the dealer on the way home and they are contacting Lippert to see about replacing.Click image for larger version
Name:	ImageUploadedByForest River Forums1395072454.680275.jpg
Klbrown53 is offline   Reply With Quote
Old 03-17-2014, 11:24 AM   #8
After seeing others bent, I removed mine and reinforced them. Also modified a set to put in front of the axles and I can just about lift the front tires off the ground before it trips the 20A breaker. Also replaced the strap supports with 3/4" pipe with flattened ends. The jacks with the bent leg that Herk pictured were traded to me and thanks to Youroo, I traded them for the noisy set they took off his camper @ the Goshen Rally last year. I love the jacks now that I reinforced them.
ID:	47871   Click image for larger version
ID:	47872   Click image for larger version
Old 03-17-2014, 01:44 PM   #9
Thanks for the pics OldCoot. I really like the way you did yours and i think I'm going to do the same mod to mine. I'm not much of a welder but i can definitely get it fabbed up and have my friend do the welding for me.
Old 03-17-2014, 01:51 PM   #10
Suggest you get some 3/4" pipe and fab some struts to replace the straps or have your friend weld a pc of 1/4' x 3/4" or 1" bar to the outside of the factory straps to keep them from bowing.
I split a pc of 2-1/4" sq. tubing 0.150" wall for the leg reinforcements.
bent
