Old 01-27-2014, 08:47 AM   #1
THESCUBADOC's Avatar
best and easiest way to winterize the 8289
Brought the unit in for a few issues, and they discovered a BUSTED filter housing,,,well damned !!! I usually open the hot water tank and drain it, let the water out on the low point valves, and put some anti freeze in the pee traps,,,,didn't even now there was a filter in there..kind of half arsed place to put it,,, how would y'all recommend preparing for freeze??? I hung a 60 watt light in the compartment, and rigged it to a temperature sensitive thermostat so the light goes on at 36 degrees,,plug is on the opposite side,,,,comments??suggestions?? HELP !! don't want to replace that sucker again,,,,
2011- Dodge Ram
2014- 8289 WS Rockwood Signature
THESCUBADOC is offline   Reply With Quote
Old 01-27-2014, 09:19 AM   #2
Dovetail's Avatar
After having one break, i just take it off. Mine. Came with a large wrench to unscrew it.
Rick and Linda, Lindale, TX
2011 Flagstaff 8528 CKSS
2006 F350 SW
Camping nights 2013: 130
Camping nights 2014: 17
Dovetail is offline   Reply With Quote
Old 01-28-2014, 02:26 PM   #3
5er_tom's Avatar
60W light bulb is a great idea. I may go do that right now.
I do wonder why there is not a light on that side of the compartment. It makes it difficult to service the water filter in the evening.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2018 Ford F-350, 4x4, Diesel, CC, Long Bed
5er_tom is offline   Reply With Quote
Old 01-28-2014, 02:32 PM   #4
5er_tom's Avatar
BTW, I used compressed air to winterize my 8289. Open the drain valves, drain the water heater, open and remove the water filter, blow air in the main water inlet, open all water valves in the unit until they blow air, (don't forget he outside shower), drain the fresh water tank, pour antifreeze down all the drains and into the toilet. I also disconnect the water pump outlet line and briefly turn on the pump to discharge water that might be in the pump.
Seems to work okay. This year will be a test as we have had some very cold temps for this area.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
Old 02-02-2014, 09:23 AM   #5
PhoneDude 8289's Avatar
Ditto with 5er tom. The only additional thing I do is bypass the water heater before blowing out the lines.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 02-12-2014, 07:55 AM   #6
RalphieAdie's Avatar
Same as all of the above. The water filter was a huge pain in the ???, and caused no end of problems taking the thing off and on each time we winterized, so we took it off completely. MUCH easier to blow out the lines with out it. We use an external water filter now.
Ralph & Adrienne
2016 Flagstaff 8528CKWSA
2012 GMC Sierra 2500HD 6.0L
RalphieAdie is offline   Reply With Quote
Old 02-12-2014, 08:12 AM   #7
I also do the compressed air method. Fast and have done it a few years without any issue.
KQ2N is offline   Reply With Quote
Old 02-12-2014, 08:52 AM   #8
I remove the cap from the fresh water tank and pull the anode from the hot water tank. I open all the faucets and low point drains, connect my air compressor to the fresh water inlet and let it run. While it's running I go inside and flush the stool. Then I pour a small amount of RV anti freeze into each trap. I'm done
comfun1 is offline   Reply With Quote
Old 02-12-2014, 09:21 AM   #9
Why do you remove the Cap from the (Fresh water Tank)? Youroo!!
Old 02-12-2014, 11:00 AM   #10
MarcusN's Avatar
I am new to winterizing a trailer and dealer did mine just as you did. Now that spring is coming (I hope) what needs to be done to clean out the pink stuff and ready the water systems for use? I know I need to get a 1 1/16" socket to put the anode back in but not sure of exactly what to do in what order.
Mark & Barb
2013 8289WS Platinum Pkg
2008 F350 King Ranch CC 6.4
2013 nights camped 35
MarcusN is offline   Reply With Quote
winter, winterize
