Old 07-23-2010, 06:23 PM   #21
Herk7769's Avatar
Totally Laugh My Butt Off
Originally Posted by Fort Kent Dad View Post
I read all that when we got the trailer home two years ago - extended warranty is up end of next month. If I recall it even included weight distribution bars should not be attached to the frame. I would like to think that bumper and frame are there for more than their good looks.
HAM CALLSIGN - KC3FFW
Old 07-23-2010, 06:38 PM   #22
milzat's Avatar
The 4" square bumper, if you want to call it a bumper, is there only to store the sewer drain hose. That's it. It won't support much weight for any length of time. But, the manufacturer does think it's enough to support a spare tire holder, with tire and cover.
I wouldn't store my drain hose there anyway. The movement of the hose, while towing, wears out the hose coating. Then once that's worn, the spring(slinky) starts to rust.
Take a good look at the bumper attaching point. You'll see there isn't much of a weld pass.
If you insist on mounting a bike rack to the rear of your trailer and want it to stay, have a welder run a few good passes at the frame/bumper fit. Or, receive hitch installed, attached to the "I" beam frame.
milzat is offline   Reply With Quote
Old 07-24-2010, 10:43 PM   #23
dharri770's Avatar
I have a Curt bolt-on receiver on my bumper for a 4-bike rack. Bumper seems fine, but my bike rack broke. One of the arms that supports (2) of the (4) bikes let loose. I always tie a ratchet strap on just in case....good thing because when I got home that was what was holding the bikes. After some research, there only a few racks designed for the back of a camper. Etrailer has a nice website and specs out bike racks designed for camper use. They indicate these are a bit more stout that can take the bouncing of the back of an RV. I selected the Swagman 64400 as a replacement.
2002 Ford Excursion w/ 7.3 TD, 3.73 rear
2008 Salem 26TBSS
Wife and (3 kids): 10g, 9g, 4b
dharri770 is offline   Reply With Quote
Old 07-25-2010, 11:17 AM   #24
milzat's Avatar
Click here and read the post by: Big_Johnson.
RV Bumper Hitch's - Be Aware -
Old 07-25-2010, 12:29 PM   #25
Herk7769's Avatar
Exclamation
Milzat,
Thank you very much for that post. EVERYONE should read it.
Good Job Pal,
Lou
bike, bike rack, rockwood
