Old 09-10-2016, 11:59 PM   #11
You can always go with the welded receiver option.
In the thread below, see post #2 for the 2" receiver I had welded to my frame on my Roo 19 and see post #12 for the one I had welded to my Mini Lite 2503S. My dealer's certified welder did both of them.
Installing a hitch on my roo.
As you've seen in the posts above, certain folks always like to raise the warranty issue with doing this, however:
1. The warranty is typically only a year anyway, and
2. I feel the extra steel actually strengthens the frame.
I had the Roo 19 for 3 yrs with no issues and I'm guessing it's still going strong. I've had the Mini Lite for two summers now with no issues.
Good luck.
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
Old 09-12-2016, 08:28 PM   #12
RusLwt001's Avatar
A lot of threads on this subject but here is one of the recent ones. If you have a ladder on you trailer, I recently installed and tested the one in this thread. I carried two full size Trek bikes, For extra security, both from theft and from falling and dragging on the highway, I used a chain lock and secured both to one of the stairs of the ladder... a little extra, I guess. This bike rack works great and is one like FR sells for some trailers with ladders.
Ladder bike mount
I need to amend, there were several racks mentioned in this thread, please look at the surco rack I installed, tested and posted about in pages 3 and 4 of the thread.
Russ
2016 Rockwood Windjammer 3025W
Diamond Package
2016 Ram 2500 6.4 Hemi 4x4
RusLwt001 is offline   Reply With Quote
Old 09-12-2016, 10:59 PM   #13
Do you have a picture?
Hman0109 is offline   Reply With Quote
Old 09-13-2016, 06:08 AM   #14
RusLwt001's Avatar
Several pics in that thread.
Russ
Diamond Package
Old 09-20-2016, 05:53 PM   #15
I spoke to the Forest River rep at the Hershey show and he said the ladder is rated for 350 bumpy pounds. And since a bike rake is an F R option, should be no problem and is a go.
2017 Mini Lite 2906S front kitchen
2005 Silverado 2500HD
labcamper is offline   Reply With Quote
Old 09-20-2016, 08:49 PM   #16
ToniandSal's Avatar
That is good to know. Now, I can bring my Townie, unless I just opt to put it inside for the travel.
ToniandSal is offline   Reply With Quote
Old 09-20-2016, 09:22 PM   #17
Left Coast
Originally Posted by fluidone View Post
I can see it failing if the hitch is overloaded. The bolt on I have is rated at 200 pound of load and is not rated to tow. Our bikes only weigh 25 and 30 pounds.
Working most of my life in steel construction it takes a lot of force to cause a 4 inch square tube to fail. Unless there is some internal defect there should have been indications of a pending failure. Bottom line is do a walk around your rig every stop. Mechanical stuff will fail and usually when you think all is well.
What's the wall thickness of tube?......What's the thickness of the brackets/ frame that the bumper is welded to?
Bob/Linda, 99 Dodge 2500 Cummins,2010 8280 Rockwood Ultra-lite 5er, PullRite Superglide----- I'm retired......but work part time as a pain in the ass!........... USMC.
bob caldwell is online now   Reply With Quote
Old 09-28-2016, 09:45 AM   #18
For what its worth we purchased a 2016 8328BS in May of this year. At the time of purchase we also purchased from our dealer a bike rack that attach's to the ladder (gravity type mount). After mounting and driving with 2 cruiser type bikes we found that our ladder was dented. It took us over 3 months to get a new ladder delivered and installed. From now on I will only mount/transport the bikes in the bed of the truck
bmbdcj is offline   Reply With Quote
Old 09-28-2016, 10:59 AM   #19
It's usually not the tube that fails, but the welds holding the tube to the frame.
Old 10-04-2016, 07:47 AM   #20
logspec1's Avatar
Ladder Bike Rack
I had the bumper bike rack but it rocked a lot so I have followed FR recommendation and bought the ladder bike rack. Only problem I have is that it only holds 2 bikes. As the ladder is designed for climbing on it is more secure to the trailer and designed to hold the weight unlike the bumper which is really only designed to hold a sewer hose.
Ken
2017 Rockwood 8329SS
2015 GMC Sierra 1500
"Go Navy"
logspec1 is offline   Reply With Quote
bike
