Old 02-22-2016, 03:05 PM   #11
Riverss
JTATUM65
Tpms reset
TPMS3.pdf
riverss is offline   Reply With Quote
Old 02-22-2016, 03:06 PM   #12
Riverss
JTATUM65
ooops
Old 02-22-2016, 03:56 PM   #13
jtatum65's Avatar
Originally Posted by riverss View Post
Ok got it thanks! I contacted my Ram dealer today and have to take the truck in to replace the reclining lever on the passenger seat and asked about lowering the TPMS settings, they told me ok no problem. We'll see! Did you get the 5th prep package in your truck? I did mine and love it!!! I'm averaging 15.5mpg at this time and hope it gets better with break-in.
Thanks again for the TPMS info!
Jim & Evelyn Tatum
2013 Rockwood 8289WS FW
2016 Dodge Ram 2500 Big Horn 6.4L Hemi 4x4
Nights Camped 2017 = 27
Nights Camped 2016= 33
jtatum65 is offline   Reply With Quote
Old 02-22-2016, 05:19 PM   #14
Riverss
yesbut with out the pucks
Old 02-22-2016, 05:25 PM   #15
jtatum65's Avatar
Oh so you had 5th wheel rails installed. I wants to avoid that so I can have the flat is the bed to use when hauling plywood and lumber
Jim & Evelyn Tatum
Old 02-22-2016, 05:58 PM   #16
Riverss
got my plans changed. was going to use the B&W Companion with the installed goosneck hitch. the Rockwood comes with the Reese Revolution (sidewinder) and the B&W companion hitch that attaches to the goose-neck receptacle can not be used with the Revolution so i was forced to decide did i want to have to install rails and use the B&W Patriot with the Reese king Box orrrrr. I really liked the clearance and convenience of not having to set and release a slide and knowing me i would put the cab into the cap one day. give a little and get a little o i can still use the goose-neck trailer i just remove the top part of the 5th wheel hitch and hook up i do not have to take the whole thing out.
Old 02-24-2016, 12:14 PM   #17
jtatum65's Avatar
Had the truck in the dealer for warranty issues and asked them to lower the TPMS settings to 50psi and the tires to 55psi. WOW what a difference!!!!
Thanks for the info!
Jim & Evelyn Tatum
Old 02-24-2016, 09:26 PM   #18
Riverss
yahoooo different truck now. i went to the tire mfg web site and downloaded the chart for the psi =lbs load rating and have that for my reference. i run the lowest (with in reason) pressure that i can because of the heat build up when running on hot pavement.
Old 02-25-2016, 07:24 AM   #19
jtatum65's Avatar
Yes much better ride. Just to verify, you running the Firestone Transforce AT tire correct? If so could you share that tire chart, I am not finding it on Firestones website. Probably not looking in the right place.
Thanks!!
Jim & Evelyn Tatum
Old 02-25-2016, 12:21 PM   #20
Riverss
http://commercial.firestone.com/cont...s_web_2014.pdf
look on page 6 of 9 I have the Firestone LT 275/70 R 18.
these are my stats 2015 RAM
GVW + 2 PPL + 1/2 TANK FUEL = 6780 LBS
STEERING AXLE = 3840 LBS
DRIVE AXLE = 2940 LBS
GAWR F = 5500 LBS @60 PSI
GAWR R = 6500 LBS @ 80 PSI
COMBINED WT OF CARGO + PEOPLE
NEVER EXCEED = 3543 LBS
LT275/70R18 SINGLE PSI RATING
35 40 45 50 55 60 65 70 75 80
2070 2270 2470 2680 2840 3020 3195 3360 3530 3640
rockwood, weight
