Old 11-09-2014, 08:52 AM   #11
Originally Posted by Still Kickin View Post
Just wondering the mechanics of an anti siphon valve and it's intended purpose, if you don't mind a quick lesson.
Quick lesson--(Keeps POO POO out of the F/Water supply! Youroo!!
Old 11-09-2014, 09:11 AM   #12
Witch Doctor's Avatar
It's really a back flow preventer. You have to have vaccuum for it to work which is impossible with a vent pipe. If the vent pipe blocks up then it woulds still be a preventer Vacuum breaks are only used on pressurized systems. This is no more the a black flow preventer. And Youroo, it is impossible for it to get into your fresh water system. Now get back in your treestand and get a deer.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 11-09-2014, 09:18 AM   #13
rattleNsmoke's Avatar
If you're having issues with it, others have cut the pex and installed two 90's and a small pex section effectively eliminating the valve altogether. That might be able to be done down low where the pex lines are accessible. Personally, I would go that route instead of tearing my shower off the wall. Just my .02
rattleNsmoke is offline   Reply With Quote
Old 11-09-2014, 09:50 PM   #14
There not connected. Are you kidding or just have no idea.
Old 11-09-2014, 10:15 PM   #15
Infractee
They are if your water supply has a Y attached to it with a hose going to water inlet and hose going to black flush.
Conversely, EVERYBODY at the CG is attached to your black tank if you have no vacuum break and something goes wrong while you are flushing.
So yes, "they're" connected.
RhoZeta is offline   Reply With Quote
Old 11-09-2014, 10:26 PM   #16
onetonford's Avatar
actually it prevents a full black tank from backing up that line and leaking out by siphoning out. Mine is located behind the closet in the bathroom it is looped higher then the toilet and that is where the valve is they do have a piece of luan screwed on but if you remove the screws you can not remove it because it is to big to get out of the cabinet you can just see the valve in there but no way can you get to it.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 11-09-2014, 10:35 PM   #17
B and B's Avatar
A simple vacuum break for garden facet will achieve the same thing. It is an issue if it is not used. Every CG could put one on the water supply but they are known to leak and drip so they don't to prevent wasted water.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 11-10-2014, 04:32 AM   #18
I don't know how (YOU) hook up your (Black Tank Rinse) but most have a (Garden Hose Fitting) that people hook up a (Fresh Water Hose ) I would call this (Connected)! I also have a Very good Idea who has Not a Clue! Youroo!!
Old 11-10-2014, 04:48 AM   #19
Well mine is impossible to get out to I would have to cut it and reroute it through the basement area. Then just use a back flow preventer. I'm surly not pulling that whole shower out. just DUMB, DUMB, and DUMBER. I just wanted know where it was incase it ever leaked. Now I know thanks to B&B.....
Old 11-10-2014, 07:30 AM   #20
Ours starting leaking yesterday on 8282ws. While flushing black tank, we noticed water leaking in storage compartment and in the bathroom vanity/sink cabinet. Shut off water to look for leak, then noticed a small black backflow preventer valve connected to two water lines. Water was dripping from the top part of the device. This one appears to be easy to replace, screw on type to water lines. I attempted to take pictures, but couldn't get a clear pic with make or model number. Need to go back to get info for replacement.
Justice is offline   Reply With Quote
black
