Old 07-23-2019, 08:09 PM   #1
Chris Pastuzyn's Avatar
Black tank flush
Tried to use the black tank flush and what a disappointment, I could have left that on for 1hr and wouldn't have even 1/2filled the tank, Any one get little to no flushing on this ? We have a Brand new 2511s ,1st time using the flusher.
Chris Pastuzyn is offline   Reply With Quote
Old 07-23-2019, 10:46 PM   #2
Your supposed to have the drain open while using the sprayer. If the value is closed you could have a issue of
" it " spraying out the roof vent.
Greg in Michigan
Greg in michigan is offline   Reply With Quote
Old 07-24-2019, 07:04 AM   #3
Yes that I know ,but not getting much spray or water in the tank, at the flow rate from the sprayer it would take 1hr to even get close to full.
Old 07-24-2019, 07:06 AM   #4
Gumpster808's Avatar
X2 on the drain valve being open while using the flush.
A clear connection on the dump hose also helps while using the flush. Makes it easy to see if anything is still getting ďrinsedĒ out of the black tank.
The flow is not the same into the tank since it is going through nozzles and not just an open pipe. Would take a while to fill using that connection.
Lynn & Dennis
Nights Camped 2017 - 35 / 2018 - 15
2014 3051S - First RV for us
2018 Hyundai Elantra Sport Toad
2015 Harley CVO (retirement bike )
2015 Challenger ( Wife's Toy)
Gumpster808 is offline   Reply With Quote
Old 07-24-2019, 07:30 AM   #5
Mr. Dan's Avatar
There is a high possibility/probability that your flush vacuum breaker/check valve is installed backwards. You need to find it and determine if it’s correct. Some are installed inside the bathroom cabinet.
See this thread for more info. Replacing Plastic Vacuum Breaker on Black Tank Flush Line
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 07-24-2019, 07:41 AM   #6
I did follow the line and found the vacuum breaker, it appears to be in the correct direction , Probably jammed or restricted, it's the plastic one, .
Old 07-24-2019, 07:49 AM   #7
x3. its not a tank fill its a tank flush. not volume of water but high pressure water to clean sides of tank. valves need to be open.
Kimber45 is offline   Reply With Quote
Old 07-24-2019, 08:22 AM   #8
I understand what its intended to do, not a lot of flushing going on . Had the clear tube and clear water came out then went old school and way more stuff came out.
Old 07-24-2019, 10:22 AM   #9
Make sure you're not using your water pressure regulator while flushing, either. Slows down the process...alot.
hinkle_e is offline   Reply With Quote
Old 07-24-2019, 07:10 PM   #10
Shouldn't be using ANYTHING that is also connected to the fresh intake except the faucet that's supplying the water.
I use a separate hose to make absolutely sure there will be no cross contamination and yes, no regulator.
As for the tank flush mechanism making a lot of noise inside tank, not sure it has to. It's not a pressure washer but more of a "rinse" mechanism. I get plenty of water flowing out the discharge hose when flush is in use and it's nice and clear.
Perhaps if it was named "Tank Rinse" people wouldn't expect the sound to be like that of a fire hose spraying around inside the tank.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 07-30-2019, 07:40 AM   #11
frank4711's Avatar
Not going to be a full rush flow like when you pull valve open for grey/black ... mine is a steady flow and get cleaner as it flushes .... it is like a sprinkler head in there after we flush tank and close we add tank treatment packet and flush 3 or 4 times so it splashes around on the ride home and is prepped for next trip...
Frank & Cindy *** Rockwood Ultra Lite *** 2019 Ram *** Remi & Sage traveling Pomskies *** TST 507 TPMS *** B&W Patriot 18K *** 3.92 axle *** Goodyear Endurance *** 32 days camped 2019 *** Predator 3500
frank4711 is offline   Reply With Quote
Old 07-30-2019, 07:58 AM   #12
It's possible you have a kinked hose between the connection and the tank. I've heard of that more than once.
Iwritecode is offline   Reply With Quote
Old 07-30-2019, 07:55 PM   #13
Is the flush that Rockwood installs a rotating sprayer like the Tornado tank flush, or is it just a fixed spray nozzle. Does anyone know what type of sprayer the factory uses?
2017 Rockwood Windjammer 3006WK
dankirk is offline   Reply With Quote
Old 08-17-2019, 07:19 PM   #14
Finally figured out what was the issue with the black tank flusher/ rinse.The check valve spring retainer was backwards putting too much pressure on the ball.Flipped it around so the spring sits inside it and presto now it has flow.
black, black tank, black tank flush, flush, tank
